Docker-compose
docker-compose up caddy
version: "3.3"
redis:
image: redis:alpine
- shared
mongo:
image: mongo:4.2.11
- mongodata:/data/db
- 127.0.0.1:${VUE_APP_MONGODB_PORT}:27017
- shared
server:
image: nertivia/server-caddy
env_file: .env
- shared
client:
image: nertivia/client-caddy
env_file: .env
- shared
image: caddy:alpine
env_file: .env
- ./cdn/Caddyfile:/etc/caddy/Caddyfile
- ./cdn/public_html:/srv
- ./cdn/ssl_certs:/root/.caddy
- 443:443
- shared
php:
image: php:fpm-alpine
working_dir: /srv
env_file: .env
- shared
image-server:
image: node:lts-alpine
working_dir: /srv/node
command: sh -c "npm i && node app.js"
env_file: .env
- shared
mongodata:
shared:
https://localtest.me {
tls /root/.caddy/localtest.me+1.pem /root/.caddy/localtest.me+1-key.pem
reverse_proxy client:8080
https://server.localtest.me {
reverse_proxy server:8181
https://cdn.localtest.me {
php_fastcgi php:9000
Starting caddy_caddy_1 ... done
Attaching to caddy_caddy_1
caddy_1 | {"level":"info","ts":1610901064.9383345,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy_1 | {"level":"info","ts":1610901064.9404683,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
caddy_1 | {"level":"info","ts":1610901064.9408333,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000449ea0"}
caddy_1 | {"level":"warn","ts":1610901064.9440534,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [localtest.me *.localtest.me]: no OCSP server specified in certificate"}
caddy_1 | {"level":"info","ts":1610901064.9442084,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"server.localtest.me","server_name":"srv0"}
caddy_1 | {"level":"info","ts":1610901064.9442265,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"cdn.localtest.me","server_name":"srv0"}
caddy_1 | {"level":"info","ts":1610901064.9442306,"logger":"http","msg":"skipping automatic certificate management because one or more matching certificates are already loaded","domain":"localtest.me","server_name":"srv0"}
caddy_1 | {"level":"info","ts":1610901064.9442337,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy_1 | {"level":"info","ts":1610901064.9452515,"logger":"tls","msg":"cleaned up storage units"}
caddy_1 | {"level":"info","ts":1610901064.945343,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
caddy_1 | {"level":"info","ts":1610901064.9453528,"msg":"serving initial configuration"}
