There is an unauthenticated API I would like to protect with Caddy. I would like to be able to allow access if the request is either coming from a whitelisted IP address, or if a secret is provided in the Authorization
header.
Here’s the caddyfile I wrote to achieve this:
mydomain.example.com {
@notAuthIP not client_ip 192.168.1.2 192.168.1.6
@authHeader `{header.Authorization} == 'mysecret'`
@notAuthHeader `{header.Authorization} != 'mysecret'`
@notWhitelisted {
@notAuthIP
@notAuthHeader
handle @notWhitelisted {
respond 403
handle @authHeader {
reverse_proxy http://internal.example.com
When I try to validate my configuration, I get this error:
caddy validate --adapter caddyfile --config api.caddyfile
Error: adapting config using caddyfile: getting matcher module '@notAuthHeader': module not registered: http.matchers.@notAuthHeader
caddy version
I used the official method to install the caddy-stable repo on an up-to-date Debian 12.6 (x86_64).
