Hello,
I am trying to get caddy working with photoview in docker (docker compose). Photoview uses port 8000 and I setup caddy as a reverse proxy 80 → 8000. I have been working on this for days and also searching for answers…
If expose port 8000 to test photoview directly, I get html returned for:
curl -vL 127.0.0.1:8000
** To test photoview I adding port mapping**
but it fails on port 80 (from host)
* Trying 127.0.0.1:80...
* Connected to 127.0.0.1 (127.0.0.1) port 80 (#0)
> GET / HTTP/1.1
> Host: 127.0.0.1
> User-Agent: curl/7.81.0
* Recv failure: Connection reset by peer
* Closing connection 0
curl: (56) Recv failure: Connection reset by peer
"level":"info","ts":1696989107.3244312,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1696989107.326113,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"warn","ts":1696989107.326193,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1696989107.3262837,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0001c2a80"}
{"level":"info","ts":1696989107.3264422,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1696989107.3264537,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1696989107.326467,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1696989107.3265903,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1696989107.3266044,"msg":"serving initial configuration"}
Docker version 24.0.5, build 24.0.5-0ubuntu1~22.04.1
caddy is latest
docker compose
kubuntu 22.04
version: "3"
db:
image: mariadb:10.5
container_name: db
restart: always
- MYSQL_DATABASE=photoview
- MYSQL_USER=photoview
- was password
- MYSQL_RANDOM_ROOT_PASSWORD=1
- db_data:/var/lib/mysql
photoview:
image: viktorstrate/photoview:2
container_name: photoview
restart: always
#ports:
# - 8000:8000
expose:
- 8000
depends_on:
- db
- PHOTOVIEW_DATABASE_DRIVER=mysql
- PHOTOVIEW_MYSQL_URL=photoview:photosecret@tcp(db)/photoview
- PHOTOVIEW_LISTEN_IP=127.0.0.1
- PHOTOVIEW_LISTEN_PORT=8000
- PHOTOVIEW_MEDIA_CACHE=/app/cache
- api_cache:/app/cache
- /home/gdan/photos/:/photos:ro
#networks:
#- proxy-network
image: caddy:latest
container_name: reverse_proxy
depends_on:
- photoview
- ./site:/srv
- caddy_data:/data
- caddy_config:/config
#networks:
#- proxy-network
db_data:
api_cache:
caddy_data:
caddy_config:
#networks:
#proxy-network:
reverse_proxy 127.0.0.1:8000
and tried based on some suggested similar topics
reverse_proxy photoview:8000
