Not able to generate TLS certificate
Hi. I am trying to setup a WP Network and use caddy as the web server. I am not able to generate a TLS certificate for the primary domain of the WP Network.
systemctl status caddy.service:
● caddy.service - Caddy
     Loaded: loaded (/etc/systemd/system/caddy.service; enabled; preset: enabled)
     Active: active (running) since Mon 2023-05-15 13:06:01 IST; 3min 42s ago
   Main PID: 32100 (caddy)
      Tasks: 11 (limit: 7064)
     Memory: 15.1M
        CPU: 215ms
             └─32100 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
May 15 13:09:35 GreenCloud.1669629768 caddy[32100]: {"level":"debug","ts":1684136375.2817886,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/newOrder","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.6.4 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["272"],"Content-Type":["application/json"],"Date":["Mon, 15 May 2023 07:39:35 GMT"],"Location":["https://acme.zerossl.com/v2/DV90/order/t_7bedyXMYB8jDmliLH5bw"],"Replay-Nonce":["PJzuBRD6vn6ZfgMJBqDhl3rc2bJFmmjOXqcLhwFxY2k"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":201}
May 15 13:09:35 GreenCloud.1669629768 caddy[32100]: {"level":"debug","ts":1684136375.4625182,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/authz/R1o9ppRF1PyJ8conm5BnkA","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.6.4 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["440"],"Content-Type":["application/json"],"Date":["Mon, 15 May 2023 07:39:35 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["2_JLc1B32Xh4NTZ0ebAmzd_uOXGLrA-E2n_hjw5x59w"],"Retry-After":["5"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":200}
May 15 13:09:35 GreenCloud.1669629768 caddy[32100]: {"level":"info","ts":1684136375.4628336,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"weblin.dev","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
May 15 13:09:35 GreenCloud.1669629768 caddy[32100]: {"level":"debug","ts":1684136375.5688963,"logger":"http.stdlib","msg":"http: TLS handshake error from 2.58.57.54:39524: EOF"}
May 15 13:09:36 GreenCloud.1669629768 caddy[32100]: {"level":"error","ts":1684136376.146983,"logger":"http.acme_client","msg":"cleaning up solver","identifier":"weblin.dev","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.weblin.dev\" (usually OK if presenting also failed)"}
May 15 13:09:36 GreenCloud.1669629768 caddy[32100]: {"level":"debug","ts":1684136376.253052,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/authz/R1o9ppRF1PyJ8conm5BnkA","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.6.4 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["122"],"Content-Type":["application/json"],"Date":["Mon, 15 May 2023 07:39:36 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["alAMAlThtmWdCgXeTKtqB2CQ7ikH_OrBOUy-v_9bitI"],"Retry-After":["86400"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":200}
May 15 13:09:36 GreenCloud.1669629768 caddy[32100]: {"level":"error","ts":1684136376.2532098,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"weblin.dev","issuer":"acme.zerossl.com-v2-DV90","error":"[weblin.dev] solving challenges: presenting for challenge: adding temporary record for zone \"weblin.dev.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme.zerossl.com/v2/DV90/order/t_7bedyXMYB8jDmliLH5bw) (ca=https://acme.zerossl.com/v2/DV90)"}
May 15 13:09:36 GreenCloud.1669629768 caddy[32100]: {"level":"debug","ts":1684136376.2532947,"logger":"events","msg":"event","name":"cert_failed","id":"f52dafeb-a5c0-4c78-a421-1e7fa276d6d1","origin":"tls","data":{"error":{},"identifier":"weblin.dev","issuers":["acme-v02.api.letsencrypt.org-directory","acme.zerossl.com-v2-DV90"],"renewal":false}}
May 15 13:09:36 GreenCloud.1669629768 caddy[32100]: {"level":"error","ts":1684136376.2533288,"logger":"tls.obtain","msg":"will retry","error":"[weblin.dev] Obtain: [weblin.dev] solving challenges: presenting for challenge: adding temporary record for zone \"weblin.dev.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers}] (order=https://acme.zerossl.com/v2/DV90/order/t_7bedyXMYB8jDmliLH5bw) (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":4.390968123,"max_duration":2592000}
May 15 13:09:40 GreenCloud.1669629768 caddy[32100]: {"level":"debug","ts":1684136380.569087,"logger":"http.stdlib","msg":"http: TLS handshake error from 2.58.57.54:39534: EOF"}
  1. Downloaded caddy bin file combined with cloudflare module from your website. https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fcaddy-dns%2Fcloudflare
  2. Moved it to /usr/bin/caddy with executable permission.
  3. Copied the custom caddy.service file to /etc/systemd/system/
  4. Copied the Caddyfile to /etc/caddy/
  5. Added cloudflare auth token to environment file (~/.bashrc) - export CLOUDFLARE_AUTH_TOKEN=redacted
  6. Created www directory and /var/lib/caddy/ with appropriate permissions. Owner & Group being www-data
  7. Started Caddy Service and enabled it.
OS: Debian 12 (Bookworm)
Architecture: x86-64
systemd. Not using docker.
# caddy.service
# for your installation.
Type=notify
User=www-data
Group=www-data
PrivateDevices=yes
Restart=always
    storage file_system /var/lib/caddy
    admin off
    email redacted
    acme_dns cloudflare {env.CLOUDFLARE_AUTH_TOKEN}
    on_demand_tls {
        interval 2m
        burst    5
https:// {
        on_demand
    root * /var/www/html/htdocs/
    php_fastcgi unix//run/php/php-fpm.sock
    file_server {
		precompressed br
        -Server
        Cache-Control "max-age=14400"
        Permissions-Policy "interest-cohort=()"
        Content-Security-Policy "default-src https: 'unsafe-eval' 'unsafe-inline'; object-src 'none'"
    @cache {
	not header_regexp Cookie "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_logged_in"
	not path_regexp "(/wp-admin/|/xmlrpc.php|/wp-(app|cron|login|register|mail).php|wp-.*.php|/feed/|index.php|wp-comments-popup.php|wp-links-opml.php|wp-locations.php|sitemap(index)?.xml|[a-z0-9-]+-sitemap([0-9]+)?.xml)"
	not method POST
	not expression {query} != ''
    route @cache {
        try_files /wp-content/cache/cache-enabler/{host}{uri}/https-index.html /wp-content/cache/cache-enabler/{host}{uri}/index.html {path} {path}/index.php?{query}
    @disallowed {
        path /xmlrpc.php
        path *.sql
        path *.zip
        path *.tar
        path *.bak
        path /wp-content/uploads/*.php
    rewrite @disallowed '/index.php'
Cloudflare token permissions:
UFW Firewall Rules:
I have found the issue. if I use the environment variable then it won’t work but if I directly paste the cloudflare api token into the caddyfile then it works.
I wonder why the caddy file is not able to read from the environment file ~/.bashrc or /etc/environment
export CLOUDFLARE_AUTH_TOKEN=abc-def
Directly using the token in caddyfile like this works - acme_dns cloudflare abc-def
Am I pasting into the wrong environment file?
@matt @francislavoie
This error message suggests to me that your cloudflare API key was invalid.
That’s not the right place to put the environment variables. Caddy runs as the caddy user, which doesn’t have the same HOME as your current user. Also services don’t use bash, so bashrc is not useful; that file is only for your shell sessions as a user.
Please read the docs for how to use Caddy as a systemd service, including the section on overrides which explains how to set your environment variables:
Also I recommend installing our apt repo instead of manually setting up the service. It’s faster and more reliable, plus you’ll get updates to the support files. See this page in the docs for how to swap in your custom build:
