Noob to Caddy, receiving 404 error on sub paths
I am a noob with Caddy. I am attempting to have Caddy serve a static Vue app. When I issue a request to https://fiddleshows.fiddlemon.com everything works correctly. However if I issue a request with any sub pages, for example https://fiddleshows.fiddlemon.com/tabs/my-shows, the server returns a 404 error.
What needs to be changed to eliminate the 404 error?
The server returns a 404 error when any sub pages are included in the request
v2.7.6
> sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https curl
> curl -1sLf 'https://dl.cloudsmith.io/public/caddy/stable/gpg.key' | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
> curl -1sLf 'https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt' | sudo tee /etc/apt/sources.list.d/caddy-stable.list
> sudo apt update
> sudo apt install caddy
Ubuntu 22.04.4 LTS
sudo systemctl start caddy
# caddy.service
# for your installation.
Type=notify
fiddleshows.fiddlemon.com {
root * /home/ubuntu/FiddleShows/
See Common Caddyfile Patterns — Caddy Documentation, you probably need try_files to have Caddy rewrite requests to unknown files to your index.
You shouldn’t be serving your app from /home, it can typically cause file permission issues. Move your site to /srv or /var/www/html instead.
Thanks, try_files, solved the problem.
