Non-documented difference between handle & route?
From my understanding, I don’t see any difference between the following two configurations. They should both act the same. However, the route version seem to have a different path when querying the reverse proxy.
I feel like I overlooked something but i’m not sure what.
Thank you in advance for your eventual answer :slight_smile: !
It is documented:
See the “similar directives” section which explain the differences.
Also, handle, handle_path, and route are all different, I notice your config uses handle_path, which manipulates the request path internally.
Thank you for your replies.
My issue was with the directive order. By placing the rewrite before the uri striping directive, I managed to get the same behavious as handle_path.
You might find this wiki article helpful:
