Hello,
I try to use caddy as proxy for my api and now I’m at the logging part.
Following to https://caddyserver.com/docs/proxy I could use {upstream} as placeholder, but I only get - as value.
Hello,
Hi @Barbers,
I tested it just now on Caddy 0.11.3.
:2015 {
proxy / localhost:2016
log / stdout "{common} /// {upstream}"
:2016 {
status 200 /
~/Projects/test
➜ curl -I localhost:2015
HTTP/1.1 200 OK
Date: Mon, 11 Feb 2019 01:25:01 GMT
Server: Caddy
Server: Caddy
~/Projects/test
➜ caddy
http://:2015
http://:2016
::1 - - [11/Feb/2019:11:25:01 +1000] "HEAD / HTTP/1.1" 200 0 /// http://localhost:2016
If you’re fully updated and still having issues, post your Caddyfile and we can take a look.
Hi @Whitestrake,
after some time I was able to trace it down to the header I set.
Please try the following.
:2015 {
header / Access-Control-Allow-Origin *
log / stdout “{common} /// {upstream}”
:2016 {
status 200 /
Ahh, yep. Reproduced the issue on my end, it’s a bug.
Could you go to https://github.com/mholt/caddy/issues/new and fill out an issue template for us? Feel free to link this thread.
Looking at the code…
The log directive attaches a Replacer to the ResponseRecorder that each successive directive can add placeholders to (such as proxy adding {upstream}): https://github.com/mholt/caddy/blob/1867ded14c82cd2ab296df8d783bbc880360d37d/caddyhttp/log/log.go#L47-L50
Looks like header actually wraps the ResponseRecorder in a ResponseWriterWrapper which has its own new Replacer: https://github.com/mholt/caddy/blob/1867ded14c82cd2ab296df8d783bbc880360d37d/caddyhttp/header/header.go#L37-L40
I assume that the proxy directive consequently adds the placeholder to the wrapper’s Replacer instead of the recorder’s Replacer: https://github.com/mholt/caddy/blob/1867ded14c82cd2ab296df8d783bbc880360d37d/caddyhttp/proxy/proxy.go#L189-L191
Whereas the recorder’s Replacer is the one that is used to generate the actual log output: https://github.com/mholt/caddy/blob/1867ded14c82cd2ab296df8d783bbc880360d37d/caddyhttp/log/log.go#L84
I’ve determined a workaround.
As long as your proxy is in effect for all requests where you need that header, you can use the header_downstream subdirective to have the proxy itself append the header.
:2015 {
proxy / localhost:2016 {
header_downstream Access-Control-Allow-Origin *
:2016 {
status 200 /
~/Projects/test
HTTP/1.1 200 OK
Access-Control-Allow-Origin: *
Date: Tue, 12 Feb 2019 03:09:12 GMT
Server: Caddy
Server: Caddy
::1 - - [12/Feb/2019:13:09:12 +1000] "HEAD / HTTP/1.1" 200 0 /// http://localhost:2016
