No solver for remaining challenge
I’m configuring caddy to use the cloudflare DNS-01 challenge. I’ve already built cloudflare using xcaddy with the custom dns module for cloudflare.
ERROR	tls.obtain	could not get certificate from issuer	{"identifier": "*.artello.network", "issuer": "acme.zerossl.com-v2-DV90", "error": "[*.artello.network] solving challenges: *.artello.network: no solvers available for remaining challenges (configured=[http-01 tls-alpn-01] offered=[dns-01] remaining=[dns-01]) (order=https://acme.zerossl.com/v2/DV90/order/7aJU_kELOZlHLRKCqpH0JQ) (ca=https://acme.zerossl.com/v2/DV90)"}
Caddy version 2.7.6
My build script is located here uplink-caddy/instellar.yml at develop · upmaru/uplink-caddy · GitHub
I’m running caddy using
Alpine linux 3.18
caddy list-modules
  Standard modules: 106
cache
caddy.storage.s3
dns.providers.cloudflare
http.handlers.cache
  Non-standard modules: 4
#!/sbin/openrc-run
# shellcheck shell=bash
name="uplink-caddy"
# shellcheck disable=2034
description="uplink-caddy service"
extra_commands="logs"
supervisor="s6"
s6_service_path="${RC_SVCDIR}/s6-scan/uplink-caddy"
logs() {
  export HOME=/var/lib/uplink-caddy
  cd /var/lib/uplink-caddy
  command=/usr/bin/tail
  /var/lib/uplink-caddy/bin/env-exec "${command} -f -n 100 /var/log/uplink-caddy/current"
depend() {
  need net s6-svscan
start_pre() {
  if [ ! -L "${RC_SVCDIR}/s6-scan/uplink-caddy" ]; then
    echo "----- Updating Service files -----"
    ln -s "/var/lib/uplink-caddy/service" "${RC_SVCDIR}/s6-scan/uplink-caddy"
  fi
    "admin":
        "identity":
            "identifiers":
                "redacted"
            "issuers":
                    "challenges":
                        "dns":
                            "provider":
                                "api_token": "redacted",
                                "name": "cloudflare"
                        "http":
                            "alternate_port": 0,
                            "disabled": false
                        "tls-alpn":
                            "disabled": false
                    "module": "acme"
    "apps":
        "http":
            "servers":
                "uplink":
                    "listen":
                        ":443"
                    "listener_wrappers":
                            "wrapper": "proxy_protocol"
                            "wrapper": "tls"
                    "logs":
                        "default_logger_name": "default"
                    "routes":
                            "group": "installation_1684",
                            "handle":
                                    "handler": "reverse_proxy",
                                    "health_checks":
                                        "passive":
                                            "fail_duration": "10s",
                                            "max_fails": 3,
                                            "unhealthy_latency": "30s",
                                            "unhealthy_request_count": 80,
                                            "unhealthy_status":
                                                500,
                                                501,
                                                502,
                                                503,
                                                504
                                    "load_balancing":
                                        "selection_policy":
                                            "policy": "least_conn"
                                    "upstreams":
                                            "dial": "laraone-19283d62-01:8000",
                                            "max_requests": 100
                            "match":
                                    "host":
                                        "*.artello.network"
                                    "path":
                            "terminal": false
    "logging":
        "logs":
            "default":
                "encoder":
                    "format": "console"
                "writer":
                    "output": "stdout"
        "sink":
            "writer":
                "output": "discard"
    "storage":
        "access_id": "redacted",
        "bucket": "instellar-staging",
        "host": "redacted",
        "module": "s3",
        "prefix": "uplink-1682",
        "secret_key": "redacted"
Your config sets the issuers for the admin endpoint, not for your website. The configuration for the web services (not admin endpoint) is in the tls app:
The easiest way to know where-to-put-what in the JSON is to start with the Caddyfile, run caddy adapt --adapter caddyfile --config ./your-configuration, then learn how the adapt the necessary pieces into your JSON.
Thank you!
