This is probably because LE issues certificates before their OCSP response is ready.
It’s only a matter of a few seconds (usually, although that can’t be guaranteed) and I think I heard they want to fix that soon, so it might start going away. There’s a TODO in the Caddy code to handle this situation, but frankly I think this is a bug in the CAs, and handling it properly makes things complicated, and adds seconds before your site can be served.
Anyway, the next time OCSP staples are fetched (a few hours), it should be good to go, unless their CDN cached the error response…
