NO IP, Caddy, Jellyfin, Raspberry - No Certificate
I want to access jellyfin from remote by adding caddy as reverse proxy on a raspberry PI4 with raspberryOS 64bit lite. I don’t get the certificate, when running caddy. See logs
Jan 19 17:13:09 xxxxx caddy[829]: {“level”:“error”,“ts”:1768839189.8486156,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“xxxxx.ddns.net”,“issuer”:“acme-v02.api.letsencrypt.org-directory”,“error”:“HTTP 400 urn:ietf:params:acme:error:connection - 92.116.66.18: Fetching http://xxxxx.ddns.net/.well-known/acme-challenge/SUyR4Tek4Pgjs6dXAsz3D1HE5qVIvSsRRvzY9moefNc: Error getting validation data”}Jan 19 17:13:09 xxxxx caddy[829]: {“level”:“error”,“ts”:1768839189.8487456,“logger”:“tls.obtain”,“msg”:“will retry”,“error”:“[xxxxx.ddns.net] Obtain: [xxxxx.ddns.net] solving challenge: xxxxx.ddns.net: [xxxxx.ddns.net] authorization failed: HTTP 400 urn:ietf:params:acme:error:connection - 92.116.66.18: Fetching http://xxxxx.ddns.net/.well-known/acme-challenge/SUyR4Tek4Pgjs6dXAsz3D1HE5qVIvSsRRvzY9moefNc: Error getting validation data (ca=https://acme-staging-v02.api.letsencrypt.org/directory)”,“attempt”:3,“retrying_in”:120,“elapsed”:189.998216537,“max_duration”:2592000}
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/gpg.key’ | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt’ | sudo tee /etc/apt/sources.list.d/caddy-stable.list
chmod o+r /usr/share/keyrings/caddy-stable-archive-keyring.gpg
chmod o+r /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
Raspberry PI4 with Raspberry OS Trixie, Caddy, Jellyfin
sudo systemctl status caddy
sudo systemctl start caddy
sudo systemctl stop caddy
sudo systemctl restart caddy
journalctl -f -u caddy
No Docker
# domain name.
        admin :2020
#:80 {
#       root * /usr/share/caddy
#       file_server
        # php_fastcgi localhost:9000
xxxxx.ddns.net {
    # Reverse proxy to Jellyfin's internal address and port
    reverse_proxy 127.0.0.1:8096
    # Optional: Redirect HTTP to HTTPS (Caddy does this automatically)
    # header Strict-Transport-Security max-age=31536000;
    # Optional: Enable compression for faster streaming
    # encode gzip zstd
    # Optional: Set a custom port if needed (e.g., 443 for standard HTTPS)
    # tls {
    #     protocols tls1.2 tls1.3
actual status… I configured the NO-IP Domain a little bit.
Now that is the actual log of caddy
Jan 19 20:47:59 xxxxx caddy[1482]: {"level":"info","ts":1768852079.5195818,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"xxxxx.ddns.net"}
Jan 19 20:47:59 xxxxx caddy[1482]: {"level":"info","ts":1768852079.5243683,"logger":"http","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/259022443","account_contact":[]}
Jan 19 20:48:00 xxxxx caddy[1482]: {"level":"error","ts":1768852080.8859663,"msg":"validating authorization","problem":{"type":"urn:ietf:params:acme:error:rateLimited","title":"","detail":"Service busy; retry later.","instance":"","subproblems":null},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/259022443/30798577453","attempt":1,"max_attempts":3,"stacktrace":"github.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.1.2/client.go:152\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.24.0/acmeissuer.go:489\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.24.0/acmeissuer.go:382\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.10.2/modules/caddytls/acmeissuer.go:288\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.24.0/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.24.0/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.24.0/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.24.0/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).manageOne.func1\n\tgithub.com/caddyserver/certmagic@v0.24.0/config.go:415\ngithub.com/caddyserver/certmagic.(*jobManager).worker\n\tgithub.com/caddyserver/certmagic@v0.24.0/async.go:73"}
Jan 19 20:48:00 xxxxx caddy[1482]: {"level":"error","ts":1768852080.8864136,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"xxxxx.ddns.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 503 urn:ietf:params:acme:error:rateLimited - Service busy; retry later."}
Jan 19 20:48:00 xxxxx caddy[1482]: {"level":"error","ts":1768852080.8865397,"logger":"tls.obtain","msg":"will retry","error":"[xxxxx.ddns.net] Obtain: [xxxxx.ddns.net] solving challenge: getting authorization at https://acme-staging-v02.api.letsencrypt.org/acme/authz/259022443/21265697503: attempt 3: https://acme-staging-v02.api.letsencrypt.org/acme/authz/259022443/21265697503: HTTP 503 urn:ietf:params:acme:error:rateLimited - Service busy; retry later. (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":3,"retrying_in":120,"elapsed":189.95024049,"max_duration":2592000}
Hi there!
The second error you are seeing (HTTP 503 … Service busy) is likely a temporary issue with the Let’s Encrypt Staging environment or a result of too many retries. It usually resolves itself if you wait a bit.
However, the first log shows the real problem that needs to be fixed:
Error getting validation data … HTTP 400 urn:ietf:params:acme:error:connection
This means Let’s Encrypt attempted to connect to your Raspberry Pi on Port 80 to validate your domain, but the connection failed. Since you are running this at home with No-IP, this is usually caused by one of two things:
Port Forwarding: Have you logged into your home router and forwarded ports 80 and 443 to the internal IP address of your Raspberry Pi? Without this, traffic from the internet hits your router and stops there.
Firewall / ISP: Check if your Raspberry Pi’s firewall (ufw or iptables) allows incoming traffic on ports 80/443. Also, ensure your ISP allows you to open ports (some ISPs use CGNAT, which prevents port forwarding).
To test this: Try to access your domain from a device outside your home network (like your phone on 4G/5G). If you cannot load a page (even an empty one), Let’s Encrypt can’t reach you either.
Hello @pauloappbr
thank you for your answer. I did everything you wrote before and it didn’t work.
Yesterday I was so desperate, that I delete the NO IP domain, created a new one under NO IP, started caddy with
“caddy reverse-proxy --from example.com --to 127.0.0.1:8096”
and once it got the certificate. Now it is running.
I didn’t change anything with the ports, after I allowed everything on router and raspberry.
Thanks a lot fo confirmation and help
Case closed :smiley:
OK, I did not see the problem. The command worked once for me an therefor not anymore.
Now I found the crucial difference.
I seem to started the command not like described on the jellyfin page
with
but with
sudo caddy reverse-proxy --from example.com --to 127.0.0.1:8096
So what do I have to do that caddy starts with sudo my configuration
xxxxx.ddns.net {
    # encode gzip zstd
    # tls {
Thanks again
