Homer-Sim
(Homer Sim)
July 12, 2018, 7:43pm
21
I did what ou suggested last time. I forwarded to a different virtual server with a fresh apache server on port 80.
it was working with broehlis url.
so the NAT is ok and was working for years …
I checked status of ubuntu firewall and status gave me disabled …
Just to confirm, you’re using iptables to check this and not ufw, right?
Could be some Docker networking shenanigans, although I’ve never seen it before. If the issue is definitely on the Caddy host’s end, it would imply that there IS some packet filtering going on, and that it’s excluding packets from non-private networks for some reason.
Homer-Sim
(Homer Sim)
July 13, 2018, 5:16am
23
I did indeed just checked ufw
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy DROP)
DOCKER-ISOLATION all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
DOCKER all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (2 references)
ACCEPT tcp -- anywhere 172.17.0.10 tcp dpt:http
ACCEPT tcp -- anywhere 172.17.0.10 tcp dpt:https
ACCEPT tcp -- anywhere 172.17.0.12 tcp dpt:mysql
ACCEPT tcp -- anywhere 172.17.0.11 tcp dpt:mysql
ACCEPT tcp -- anywhere 172.17.0.9 tcp dpt:9001
ACCEPT tcp -- anywhere 172.17.0.9 tcp dpt:1883
ACCEPT tcp -- anywhere 172.17.0.4 tcp dpt:http
ACCEPT tcp -- anywhere 172.17.0.4 tcp dpt:https
ACCEPT tcp -- anywhere 172.17.0.8 tcp dpt:http
ACCEPT tcp -- anywhere 172.17.0.3 tcp dpt:mysql
ACCEPT tcp -- anywhere 172.17.0.5 tcp dpt:8384
ACCEPT tcp -- anywhere 172.17.0.7 tcp dpt:9000
ACCEPT tcp -- anywhere 172.17.0.13 tcp dpt:http
ACCEPT tcp -- anywhere 172.17.0.13 tcp dpt:https
ACCEPT tcp -- anywhere 172.17.0.14 tcp dpt:http-alt
ACCEPT tcp -- anywhere 172.17.0.6 tcp dpt:https
Chain DOCKER-ISOLATION (1 references)
DROP all -- anywhere anywhere
RETURN all -- anywhere anywhere
Homer-Sim
(Homer Sim)
July 13, 2018, 7:15pm
24
I am still fighting.
I stopped caddy container on my main server and added a nginx container.
This one is also accessable with port 80 from outside.
Next will be adding a fresh cady container and then I will try to access it in the same way …
Homer-Sim
(Homer Sim)
July 13, 2018, 8:18pm
25
YAHOOOOOOOO
We were maybe all a little blind …
find the mistake
pass.homer-s.my-wan.de
#bitwarden
proxy / https://192.168.100.70:443 {
websocket
insecure_skip_verify
log /etc/log/pass_access.log
errors /etc/log/pass_errors.log
tls mymail@mail.de
SO MANY THANKS TO ALL OF YOU!!!
system
(system)
Closed
October 11, 2018, 8:18pm
26
