No certificate matching TLS ClientHello
Im unable to connect to my homeserver using tailscale domain name. Im getting some error no certificate matching TLS ClientHello. If I try to connect with my tailscale ip it works fine.
 tls: client offered only unsupported versions: [301]
{"CipherSuites":[51914,4865,4866,4867,49196,49195,52393,49200,49199,52392,49162,49161,49172,49171,157,156,53,47,49160,49170,10],"ServerName":"azabache.narwhal-nominal.ts.net","SupportedCurves":[14906,29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,515,2053,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[51914,772,771,770,769],"Conn":{}}}}
As far as I remember I haven’t changed anything besides updating ubuntu, caddy and tailscale.
$ curl -vL azabache.narwhal-nominal.ts.net
*   Trying 100.126.156.31:80...
* Connected to azabache.narwhal-nominal.ts.net (100.126.156.31) port 80 (#0)
> GET / HTTP/1.1
> Host: azabache.narwhal-nominal.ts.net
> User-Agent: curl/8.1.2
< Connection: close
< Location: https://azabache.narwhal-nominal.ts.net/
< Server: Caddy
< Date: Sun, 26 Nov 2023 09:10:05 GMT
< Content-Length: 0
* Closing connection 0
* Issue another request to this URL: 'https://azabache.narwhal-nominal.ts.net/'
*   Trying 100.126.156.31:443...
* Connected to azabache.narwhal-nominal.ts.net (100.126.156.31) port 443 (#1)
* ALPN: offers h2,http/1.1
*  CAfile: /etc/ssl/cert.pem
*  CApath: none
* LibreSSL/3.3.6: error:1404B438:SSL routines:ST_CONNECT:tlsv1 alert internal error
* Closing connection 1
curl: (35) LibreSSL/3.3.6: error:1404B438:SSL routines:ST_CONNECT:tlsv1 alert internal error
{"level":"debug","ts":"2023-11-26T09:12:02.461Z","logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"100.126.186.99","remote_port":"55779","server_name":"azabache.narwhal-nominal.ts.net","remote":"100.126.186.99:55779","identifier":"azabache.narwhal-nominal.ts.net","cipher_suites":[14906,4865,4866,4867,49196,49195,52393,49200,49199,52392,49162,49161,49172,49171,157,156,53,47,49160,49170,10,22016],"cert_cache_fill":0.0006,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":"2023-11-26T09:12:02.462Z","logger":"http.stdlib","msg":"http: TLS handshake error from 100.126.186.99:55779: no certificate available for 'azabache.narwhal-nominal.ts.net'"}
{"level":"debug","ts":"2023-11-26T09:12:02.476Z","logger":"http.stdlib","msg":"http: TLS handshake error from 100.126.186.99:55780: tls: client offered only unsupported versions: [301]"}
{"level":"debug","ts":"2023-11-26T09:12:02.482Z","logger":"events","msg":"event","name":"tls_get_certificate","id":"94d43bac-690c-4176-bc77-53175c9f1905","origin":"tls","data":{"client_hello":{"CipherSuites":[51914,4865,4866,4867,49196,49195,52393,49200,49199,52392,49162,49161,49172,49171,157,156,53,47,49160,49170,10],"ServerName":"azabache.narwhal-nominal.ts.net","SupportedCurves":[14906,29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,515,2053,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[51914,772,771,770,769],"Conn":{}}}}
{"level":"debug","ts":"2023-11-26T09:12:02.482Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"azabache.narwhal-nominal.ts.net"}
{"level":"debug","ts":"2023-11-26T09:12:02.482Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.narwhal-nominal.ts.net"}
{"level":"debug","ts":"2023-11-26T09:12:02.482Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.ts.net"}
{"level":"debug","ts":"2023-11-26T09:12:02.482Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.net"}
{"level":"debug","ts":"2023-11-26T09:12:02.482Z","logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*.*"}
{"level":"debug","ts":"2023-11-26T09:12:02.482Z","logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"100.126.186.99","remote_port":"55781","server_name":"azabache.narwhal-nominal.ts.net","remote":"100.126.186.99:55781","identifier":"azabache.narwhal-nominal.ts.net","cipher_suites":[51914,4865,4866,4867,49196,49195,52393,49200,49199,52392,49162,49161,49172,49171,157,156,53,47,49160,49170,10],"cert_cache_fill":0.0006,"load_or_obtain_if_necessary":true,"on_demand":false}
$ caddy version        130 ↵
$ sudo lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 22.04.3 LTS
Release:	22.04
Codename:	jammy
sudo service caddy start
Type=notify
        email some@email.com
        servers {
                metrics
                output file /var/log/caddy/caddy.log {
                        roll_size 500mb
                format json {
                        time_format iso8601
# PiHole
azabache.narwhal-nominal.ts.net {
        encode zstd gzip
        reverse_proxy localhost:1080
        redir / /admin
                output file /var/log/caddy/pihole.log {
                        roll_size 500mb
                format json {
                        time_format iso8601
Just a hunch, but if you remove the email line from your global options, does the behavior change?
You are right, without the email option it works again.
I thought we fixed that in the past
Should I open a new issue?
I actually think there might already be an open issue about it – I am mobile right now but will try to find it soon. If you can’t find one, then yeah please open one!
