Hi everyone,
I’m looking to run a multisite for WordPress Bedrock. It requires 2 specific rewrite rules.
specifically:
rewrite ^/(wp-.*.php)$ /wp/$1 last;
rewrite ^/(wp-(content|admin|includes).*) /wp/$1 last;
I’m not sure how to translate that in the Caddy way
my current, working, caddyfile is very simple and adapted from the Wiki for local development:
# the following config works for a single WP bedrock site on localhost
http:// {
root * /var/www/html/web
php_fastcgi wordpress:9000 {
root /var/www/html/web
Thank you!
Paul123
(Paul)
June 10, 2021, 1:33pm
#2
Not sure if this works, but you might want to try.
uri path_regexp ^/(wp-.*.php)$ /wp/$1
uri path_regexp ^/(wp-(content|admin|includes).*) /wp/$1
The second root
inside of php_fastcgi
is redundant. You can remove it and the braces.
You probably want the path_regexp
matcher, paired with the rewrite
handler:
@multisiteFirst path_regexp first ^/(wp-.*.php)$
rewrite @multisiteFirst /wp/{re.first.1}
@multisiteSecond path_regexp second ^/(wp-(content|admin|includes).*)
rewrite @multisiteSecond /wp/{re.second.1}
Thank you!
Maybe it’d be useful to add the config for it in the wiki as well, if people like me are looking to switch from nginx to caddy.
Thanks again!
Feel free to write a wiki for it. I don’t use Wordpress so I wouldn’t be the right person to do it.
Or, get Bedrock to include Caddy in their docs.
system
(system)
closed
July 10, 2021, 1:12pm
#6
