drio
(David)
March 23, 2022, 7:45pm
1
I am trying to migrate a nginx config file to caddy. How can I rewrite this?
location /.well-known/matrix/client {
add_header Access-Control-Allow-Origin '*';
return 200 '{ "m.homeserver": { "base_url": "domain here" } }';
P.S: Let me know if you are running your matrix homeserver with Caddy. Love to hear from you.
matt
(Matt Holt)
March 23, 2022, 8:41pm
2
Very easy, please see the docs: Caddyfile Directives — Caddy Documentation
handle /.well-known/matrix/client {
header Access-Control-Allow-Origin *
respond `{ "m.homeserver": { "base_url": "domain here" } }`
Since I run multiple matrix servers, if figured I put my two cents in here
If you wanna get all fancy, you could do the following to group both the /.well-known/matrix/client and /.well-known/matrix/server:
## matrix client/server delegation
handle_path /.well-known/matrix/* {
## `Content-Type: application/json` isn't required by the matrix spec
## but some browsers (firefox) and some other tooling might preview json
## content prettier when they are made aware via Content-Type
header Content-Type application/json
respond /client `{ "m.homeserver": { "base_url": "https://client-endpoint.example.com" } }`
respond /server `{ "m.server": "federation-endpoint.example.com:443" }`
## return http/404 if nothing matches
respond 404
The port in /server is, and I quote the synapse docs here :
Note, specifying a port is optional. If no port is specified, then it defaults to 8448.
After I wrote the post here, I was curious whether the synapse docs have a client/server delegation example for Caddy.
And they do!
→ synapse/docs/reverse_proxy.md at e78d4f61fc881851ab35e9a889239a61cf9805e5 · matrix-org/synapse · GitHub
They set the Content-Type header too, in addition to Access-Control-Allow-Methods and Access-Control-Allow-Headers, which aren’t necessary either, but feel free to add them if you like
And they opted to use Caddyfile#snippets with import (Caddyfile directive) — Caddy Documentation which works too, if you prefer that.
drio
(David)
March 24, 2022, 10:53am
4
Thank you @emilylange !
I forgot to check the synapse docs (I use dendrite). On that note, have you tried it? It seems it has been in beta forever. Not sure if I should use synapse instead. I was captivated with the idea of using less resources.
emilylange
(Emily Lange)
March 24, 2022, 11:58am
5
I only run/maintain synapse servers right now
I also kinda love how synapse still has
Help!! Synapse is slow and eats all my RAM/CPU!
in its README
But it is the only spec-complete implementation as of right now.
Both Dendrite (Matrix/Element people) and Conduit (famedly) are still lacking some Server2Server and Client2Server APIs.
→ dendrite/README.md at d983d17355584b7de086389e069a935f1a5510a1 · matrix-org/dendrite · GitHub
→ Issues · matrix-org/dendrite · GitHub
→ README.md · a2a7c6187228bbcbbefadaa703e5afe469b7cbfe · Famedly / Conduit · GitLab
→ Conduit 1.0 · Milestones · Famedly / Conduit · GitLab
Dendrite is becoming more and more complete, but it will still take a while before it is truly complete.
All the cool p2p demos are built on dendrite though (Matrix.org - This Week in Matrix 2022-03-18 ) and (Redirect ) and (https://matrix.org/blog/2021/05/06/introducing-the-pinecone-overlay-network ).
I can’t really speak for Conduit because I don’t follow its development as much.
Oh, and most experimental MSCs [Matrix Spec Changes] usually land in synapse first, if you care about that.
So I would argue, stick with synapse for your main matrix.org server for now and maybe run another implementation on a separate (sub-) domain
drio
(David)
March 24, 2022, 12:13pm
6
! Thank you @emilylange .
Do you hang out in any public matrix room? I’d love to join.
-drd
Glad I could help
I only really lurk in public matrix rooms, but if you are searching rooms via Element Web/Desktop (onboarding is a bit rough):
Click on the little compass icon next to your search bar/icon top-left
Click on the Matrix rooms (<server name>) dropdown if you aren’t seeing any rooms (or wanna discover another public server)
Either select an existing one or click Add a new server… and add another server like matrix.org, mozilla.org, libera.chat, gitter.im or smaller ones like ungleich.ch.
Now you should be able to see at least some public rooms
Alternatively, you could join/discover Spaces like matrix:#community:matrix.org . If you want to learn more about Spaces the following blog post by Element might be a good summary:
drio
(David)
March 24, 2022, 1:18pm
8
I understand we have public rooms in matrix. I wanted to know if you hang out in any of those so I can join too.
Thank you!
