Nginx proxying Caddy gives 404
I have two different domains served with two different web servers:
sub.domain.com (Nginx)
domain.com (Caddy)
I have to create a reverse proxy from sub.domain.com/userinfo to domain.com/userinfo, so in Nginx I have set the proxy:
location /userinfo {
        proxy_pass https://domain.com;
        proxy_pass_request_body off; # no need to send the POST body
        proxy_set_header Content-Length "";
        proxy_set_header X-Forwarded-Proto $scheme;
        # these return values are passed to the @error401 call
        auth_request_set $auth_resp_jwt $upstream_http_x_vouch_jwt;
        auth_request_set $auth_resp_err $upstream_http_x_vouch_err;
        auth_request_set $auth_resp_failcount $upstream_http_x_vouch_failcount;
The issue is that when I visit sub.domain.com/userinfo, I get a 404 response, and Caddy logs nothing.
No logs (nothing is logged on Caddy)
Static binary, downloaded from caddy website
OS: Ubuntu 22.04 (both)
Arch: x64 (both)
sudo ./caddy_linux_amd64 run
	servers {
		trusted_proxies static 0.0.0.0/0
	log
www.domain.com, domain.com, http://sub.domain.com {
    root * /var/www/vhosts/site/web/
    file_server {
        hide .htaccess
        index index.html index.htm index.php
    php_fastcgi unix//run/php/php-fpm.sock
    log
    # To capture Caddy's log (such as configuration errors)...
    log default {
        output file /var/log/caddy/caddy.log
        format console
    # other global options
# To capture the log of a particular domain in a log file (in json format)...
example.com {
        output file /var/log/caddy/access-example.com.json
    # other directives
You might want to refer the following to understand how logging works in general…
If the generic logging doesn’t help, you might turn on debugging as mentioned in Global options (Caddyfile) — Caddy Documentation .
