1. Output of caddy version
Distributor ID: Ubuntu
Description: Ubuntu 22.04.1 LTS
Release: 22.04
Codename: jammy
Client: Docker Engine - Community
Version: 20.10.22
API version: 1.41
Go version: go1.18.9
Git commit: 3a2c30b
Built: Thu Dec 15 22:28:04 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.22
API version: 1.41 (minimum version 1.12)
Git commit: 42c8b31
Built: Thu Dec 15 22:25:49 2022
Experimental: false
containerd:
Version: 1.6.15
GitCommit: 5b842e528e99d4d4c1686467debf2bd4b88ecd86
runc:
Version: 1.1.4
GitCommit: v1.1.4-0-g5fd4c4d
docker-init:
Version: 0.19.0
GitCommit: de40ad0
Docker Compose version v2.0.1
N/A docker caddy - see above
The problem I am having is webdav does not fuction. If I use it locally uisng my ip address it works, but if I use it through caddy, my webdav does not work.
The error I see in docker logs is below, there is no error in nextcloud.
{"level":"error","ts":1673983439.6325216,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 172.27.0.55:443->172.27.0.1:50784: write: broken pipe"}
{"level":"error","ts":1673983474.633873,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 172.27.0.55:443->172.27.0.1:50804: write: broken pipe"}
{"level":"error","ts":1673983509.6356308,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"write tcp 172.27.0.55:443->172.27.0.1:50796: write: broken pipe"}.
I have trouble shooted it to verify if it is Caddy or Nextcloud and got it down to Caddy. I have searched the forums, but most seemed to be related to nextcloud overall, not just webdav not working. I have gone to the webdav url and it seems to properl;y show, just shows a message that it cant be view in a browser.
