NextCloud on Caddy
Trying to set up Nextcloud to run on Caddy reverse proxy. I’ve spent hours trying to get it to work, to no avail.
Here is my caddy file:
cloud.mysite.com {
    gzip
    proxy / https://192.168.2.3:500 {
      websocket
      insecure_skip_verify
I’ve tried a lot of versions of this, but nothing works.
Here is my config file for Nextcloud:
      'trusted_domains' =>
      array (
        0 => '192.168.2.3:500',
        1 => '192.168.2.15:2015',
        2 => '192.168.2.15:443',
        3 => '192.168.2.15:80',
        4 => 'cloud.mysite.com',
        5 => 'https://cloud.mysite.com',
192.168.2.15 is Caddy. I’ve tried different trusted domains, but again, nothing works.
Whatever I do, I get 502 bad gateway.
Would really appreciate any insight!t!
Something that might tell us what’s going on is to try and pretend to be Caddy, requesting a page from Nextcloud, and see what we get.
Run the command curl -kIL https://192.168.2.3:500/ -H "Host: cloud.mysite.com" (changing cloud.mysite.com as appropriate) from the host Caddy is running on and let us know what comes back.
Not sure how much help i could be but i run Nextcloud in a docker container on a separate VM. and here is my caddyfile (with 100% non-relevant info excluded):
# Snippets
(mycommon_tls) {
  ext .html .htm .php
  root /var/www          # Change path & syntax for your OS or your preferred location!
  gzip
  tls admin@domain.com {
  header / {
# web domain server block
domain.com {
  # New log directive syntax for v0.10.x
  log /var/log/caddy/logs/access.log {                          # Change path syntax for your OS or your preferred location!
    rotate_size 1          # Rotate after 1 MB
    rotate_age  7          # Keep log files for 7 days
    rotate_keep 2          # Keep at most 2 log files
  errors /var/log/caddy/logs/error.log {                        # Change path syntax for your OS or your preferred location!
    rotate_size 1          # Set max size 1 MB
  import mycommon_tls        # Import code snippet 1 defined above
  #import mylocations        # Import code snippet 2 defined above
# NextCloud Subdomain
cloud.domain.com {
  import mycommon_tls
  proxy / https://cloud.lan.domain.com {
    log /var/log/caddy/access.cloud.log
    errors /var/log/caddy/errors.cloud.log
