I’m try to config in my stack but i receive this error everytime.
🗴 can't connect to push server: cURL error 28: Connection timed out after 30001 milliseconds.
I’m trying in many ways, but I’m too newbie to understand.
My caddyfile
# SSL
email {$ADMIN_EMAIL}
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
# Enable to see header set by upstream
{$DOMAIN} {
#acme_server
#tls internal
# Static content
root * /var/www/html
# PHP fast cgi
php_fastcgi app:9000 {
#php_fastcgi unix//run/php-fpm/nextcloud.sock { Why not work??
env front_controller_active true
env modHeadersAvailable true
env HTTPS on
trusted_proxies private_ranges
# Redirects for DAV apps
redir /.well-known/carddav /remote.php/carddav 301
redir /.well-known/caldav /remote.php/caldav 301
respond /.well-known/acme-challenge 404
respond /.well-known/pki-validation 404
# redir /.well-known/* /index.php/.well-known/webfinger 301
# redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
redir /.well-known/* /index.php{uri} 301
# Headers
# If staging acme_ca is enabled, this needs to be commented out!
# Otherwise, it is not possible to add exception
# More security hardening headers
Referrer-Policy "no-referrer"
X-Download-Options "noopen"
X-Frame-Options "SAMEORIGIN"
X-Permitted-Cross-Domain-Policies "none"
X-Robots-Tag "none"
Permissions-Policy "interest-cohort=()"
# Remove X-Powered-By header, which is an information leak
-X-Powered-By
# Replace http with https in any Location header
Location http:// https://
# Cache control
@static {
file
header @static {
Cache-Control "max-age=360"
@fonts {
path /core/fonts
header @fonts {
Cache-Control "max-age=604800"
# gzip encoding
encode {
gzip 4
minimum_length 256
match {
header Content-Type text/*
header Content-Type application/json*
header Content-Type application/javascript*
header Content-Type application/xhtml+xml*
header Content-Type application/atom+xml*
header Content-Type application/rss+xml*
header Content-Type image/svg+xml*
header Content-Type application/ld+json*
header Content-Type application/manifest+json*
header Content-Type application/vnd.geo+json*
header Content-Type application/vnd.ms-fontobject*
header Content-Type application/x-font-ttf*
header Content-Type application/x-web-app-manifest+json*
header Content-Type application/xml*
header Content-Type font/opentype*
header Content-Type image/bmp*
header Content-Type image/x-icon*
header Content-Type text/cache-manifest*
@forbidden {
path /build/*
path /tests/*
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
path /autotest
path /issue
path /indie
path /db_
path /console
handle_path /push/* {
reverse_proxy app:7867
respond @forbidden 404
