1. Output of caddy version
Install caddy via apt and run using systemd
Description: Ubuntu 20.04.5 LTS
Release: 20.04
Codename: focal
systemd
php 8.1
nextcloud 24.0.6
systemctl [start/stop/restart/status] caddy
default package unit file
cloud-bkp.die-kinderwelt.com {
output file /var/log/caddy/nextcloud.log
root * /var/www/nextcloud
php_fastcgi unix//run/php/php-fpm.sock {
env front_controller_active true # Remove index.php form url
header_up -X-Forwarded-Host
Strict-Transport-Security max-age=15768000;
redir /.well-known/carddav https://cloud-bkp.die-kinderwelt.com/remote.php/dav/ permanent
redir /.well-known/caldav https://cloud-bkp.die-kinderwelt.com/remote.php/dav/ permanent
@phpFiles {
path_regexp phpfile ^/(remote|public|cron|core/ajax/update|status|ocs/v1|ocs/v2)\.php
rewrite @phpFiles {http.regexp.phpfile.0}
rewrite /index.php/* /index.php${uri}
@forbidden {
path /build/*
path /tests/*
path /config/*
path /lib/*
path /3rdparty/*
path /templates/*
path /data/*
path /.
path /autotest
path /occ
path /issue
path /indie
path /db_
path /console
respond @forbidden 404 {
close
handle_errors {
respond "{err.status_code} {err.status_text}"
Hey there,
everything seems to run fine with the above caddy conf.
I just wanted to know if anyone has suggestions for optimizations.
I want to make sure to follow best practices.
Thanks!
