hello,
i am using some script to install nextcloud + caddy in jail. The problem is its configured that caddy is using lets encrypt … i dont need that as i want to use nginx reverse proxy on my other host to add tls/https on top of nextcloud …
is there some generic caddy configuration file for nextcloud?
i use this configuration and believe something minor has to be change so nextcloud will listen on port 80.
the script i am using >
thanks!
# debug
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
email email@pm.me
default_sni clode.duckdns.o
clode.duckdns.o {
root * /usr/local/www/nextcloud
output file /var/log/clode.duckdns.org.log
php_fastcgi 127.0.0.1:9000 {
env front_controller_active true
dns duckdns 90ad2f4b-f57b-4f4b-8094-1b04eba21b82
# enable HSTS
# Strict-Transport-Security max-age=31536000;
# client support (e.g. os x calendar / contacts)
redir /.well-known/webfinger /index.php/.well-known/webfinger 301
redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
