Nextcloud Docker Webfinger and Node info Issue
Hi everyone, hope all is well. I ran into an issue in Nextcloud. In my admin overview I only have these two issues.
  • Your web server is not properly set up to resolve “/.well-known/webfinger”.
  • Your web server is not properly set up to resolve “/.well-known/nodeinfo”.
It happened when I was added new configs for the forbidden everything was perfect. Then i saw a new redir webfinger from the link below thought i needed it. I added it in and it triggered the error. I tried everything from restoring from proxmox backup, removing the webfinger config in caddy, adding rewrites in the /var/www/html/.htcaccess no dice.
<IfModule mod_rewrite.c>
   RewriteEngine on
   RewriteRule ^/\.well-known/carddav /nextcloud/remote.php/dav [R=301,L]
   RewriteRule ^/\.well-known/caldav /nextcloud/remote.php/dav [R=301,L]
   RewriteRule ^/\.well-known/webfinger /nextcloud/index.php/.well-known/webfinger [R=301,L]
   RewriteRule ^/\.well-known/nodeinfo /nextcloud/index.php/.well-known/nodeinfo [R=301,L]
 </IfModule>
3. Caddy version: 2.7.6
4. How I installed and ran Caddy: Docker/Portainer
a. Compose file:
version: "3.8"
    image: caddy:latest
      - 443:443
      - 443:443/udp
      - /home/ubuntu/docker/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /home/ubuntu/docker/caddy/site:/srv
      - /home/ubuntu/docker/caddy/caddy_data:/data
      - /home/ubuntu/docker/caddy/caddy_config:/config
    labels:
      - com.centurylinklabs.watchtower.monitor-only=true
      - dmz
  dmz:
    external: true
b. My complete Caddy config:
example.com {
    reverse_proxy 192.168.0.1:8040
     root    * /var/www/html
     encode zstd gzip
    redir /.well-known/carddav /remote.php/dav/ 301
    redir /.well-known/caldav /remote.php/dav/ 301
    redir /.well-known/webfinger /public.php?service=webfinger 301
     php_fastcgi 127.0.0.1:2019  {
         # disable FLoC tracking
         Permissions-Policy interest-cohort=()
         # enable HSTS
     @forbidden {
                path    /.htaccess
                path    /data/*
                path    /config/*
                path    /db_structure
                path    /.xml
                path    /README
                path    /3rdparty/*
                path    /lib/*
                path    /templates/*
                path    /occ
                path    /console.php
        handle @forbidden {
                respond 404
I added this line from @ arvigeus caddy config and its was tiggered the issue.
redir /.well-known/webfinger /index.php/.well-known/webfinger 301
redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
I added those configs, I restarted caddy container (like i always do) but this time i also restarted the Nextcloud compose stack as well and it worked thank you so much.
