2.3.0
Debian 10 Buster with Caddy as a service running under the “caddy” user
systemd, no Docker
php-fpm 7.4.16 running as user caddy:caddy
Nextcloud root being /var/www/nextcloud permissions caddy:caddy 700
Nextcloud data directory being /var/nc_data with permissions caddy:caddy 770
No plans to run other webservers like e.g. Apache at the moment. Would like to stay with Caddy!
sudo systemctl start caddy
nc2-test.hfw18 {
root * /var/www/nextcloud
encode gzip zstd
tls internal
# php_fastcgi 127.0.0.1:9000 {
php_fastcgi unix//run/php/php7.4-fpm.sock {
env front_controller_active true
output file /var/log/caddy_nc.log
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
respond @forbidden 404
My test with Nextcloud on Caddy runs pretty well so far.
I have some general questions left, which would be nice if someone would answer as I am quite a newbie:
Is it generally a good idea to switch php-fpm to run as the caddy user and change ownership of the /var/www directory to the caddy-user? In a standard case this would all be the www-data user. So I decided to switch it all over. Any downsides with this? Suggestions?
Is it maybe a better idea to move the nextcloud root directory to somewhere else e.g. /srv/www or /usr/share/www ?
Or would it be a good idea to switch Caddy to run as www-data?
Thanks for your thoughts and ideas!
No errors so far.
Already got it going, but eager to learn more.
