Nextcloud behind caddy reverse proxy: too many redirects
2.3.0
I have a couple of raspberry pis, one running nextcloud in a snap and one running a Joplin server in a docker container. CAddy is running on the one also running the joplin server. For the moment, I am just trying to get the reverse proxy to Nextcloud working, and I can’t.
This is 64bit Raspberry OS; caddy is running plain, ie not in any sort of container
Nextcloud is in a snap installation, with apache, which works when contacted directly
caddy run / reload
paste full file contents here
My caddyfile is
localhost {
    respond "Hello, World. I don't believe this but it works"
    log
unclaimed.space {
    route {
        reverse_proxy /nextcloud/* https://192.168.178.46:443 {
            header_down Strict-Transport-Security "max-age=15552000;"
            header_down X-Real-IP {http.request.remote}
            header_down X-Forwarded-For {http.request.remote}
        reverse_proxy /joplin/* localhost:22300
        respond "Yes, I do have a certificate, thank you: now go away."
    log
joplin.unclaimed.space {
    reverse_proxy localhost:22300
    log
nextcloud.unclaimed.space {
     reverse_proxy http://192.168.178.46:81 {
         output file /var/log/caddy.log
         format console
# DO NOT FORGET
# to run "caddy reload" after every change
The two unproxied responses work.
The proxy to nextcloud does not.
Neither does the one to joplin, but that has to be a variant of the same problem
When I enter https://nextcloud.unclaimed.space into my browser, I get
This page isn’t workingnextcloud.unclaimed.space redirected you too many times.
Try clearing your cookies.
ERR_TOO_MANY_REDIRECTS
output of tail /var/log/caddy.log
1.6157531438012261e+09  info    http.log.access.log0    handled request {"request": {"remote_addr": "51.148.129.254:58005", "proto": "HTTP/1.1", "method": "GET", "host": "nextcloud.unclaimed.space:443", "uri": "/status.php", "headers": {"Accept": ["*/*"], "X-Request-Id": ["0b569c5d-011f-4bbb-acbf-d7241f708318"], "Connection": ["Keep-Alive"], "Accept-Encoding": ["gzip, deflate"], "Accept-Language": ["en-GB,*"], "User-Agent": ["Mozilla/5.0 (Windows) mirall/3.1.3stable-Win64 (build 20210218) (Nextcloud)"], "Authorization": ["Basic XXXXXXXXXX
"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4867, "proto": "", "proto_mutual": true, "server_name": "nextcloud.unclaimed.space"}}, "common_log": "51.148.129.254 - - [14/Mar/2021:20:19:03 +0000] \"GET /status.php HTTP/1.1\" 301 256", "duration": 0.001007843, "size": 256, "status": 301, "resp_headers": {"Date": ["Sun, 14 Mar 2021 20:19:03 GMT"], "Location": ["https://nextcloud.unclaimed.space:443/status.php"], "Content-Length": ["256"], "Content-Type": ["text/html; charset=iso-8859-1"], "Strict-Transport-Security": ["max-age=15552000;"], "X-Forwarded-For": ["51.148.129.254:58005"], "X-Real-Ip": ["51.148.129.254:58005"], "Server": ["Caddy", "Apache"]}}
╭─pi@Quinn ~
Endless googling for possible answers; adding the header lines you see into the configuration; running nextcloud on different ports; trying with http and without.
I’m sure I’m missing something obvious and stupid but I don’t know what.
There’s a couple things to talk about here.
First, I think you should use the header directive rather than header_down for the Strict-Transport-Security header. That’s more of a domain-level header, and isn’t specific to a particular proxy.
Second, it doesn’t really make sense to use header_down for X-Real-IP and X-Forwarded-For, because those headers are meant for telling the upstream app the originating IP address of the request. header_down writes those headers to the response, i.e. you’re telling the client/browser “hey, by the way this is your IP”, which isn’t useful.
What you’d actually want is header_up, but in this case, you can just remove those two lines altogether because Caddy’s reverse_proxy already adds the X-Forwarded-For header to the proxied request anyways (and X-Real-IP is redundant since X-Forwarded-For will already have that information set, and I know Nextcloud already handles that fine).
As for the issue with redirects, I don’t see a problem with your nextcloud.unclaimed.space domain that would case this. Are you sure Nextcloud is properly configured?
Try making a request with curl -v https://nextcloud.unclaimed.space/ and see what’s in the response headers.
Just FYI, proxying over HTTPS might require a bit more work, you may need to configure Caddy to trust the certificate served by Nextcloud. But it’s probably easier to just use HTTP since those services should only be directly accessible privately.
First, thank you for your help.
I had copied and pasted (of course) the header stuff from someone who seemed to have this working.
When I try curl -v nextcloud.unclaimed.space I get
* Connected to nextcloud.unclaimed.space (51.148.129.254) port 80 (#0)
> GET / HTTP/1.1
> Host: nextcloud.unclaimed.space
> User-Agent: curl/7.64.0
< Connection: close
< Location: https://nextcloud.unclaimed.space/
< Server: Caddy
< Date: Mon, 15 Mar 2021 07:42:08 GMT
< Content-Length: 0
Which suggests a misconfiguration in the nextcloud snap. Oh, God. I really don’t know how to fiddle with apache at all, (I used to use nginx) let alone inside a snap. Should I perhaps disable the apache that’s running in the nextcloud snap and put a second instance of Caddy on that pi?
ON investigation, the httpd,conf inside the snap is read only, so I am completely stuck.
That redirect is expected; Caddy serves HTTP->HTTPS redirects. You made an HTTP request with curl there. Try with this command (exactly):
Ah. Now I get something I really don’t understand :slight_smile:
*   Trying 51.148.129.254...
* TCP_NODELAY set
* Expire in 149984 ms for 3 (transfer 0x5597284c30)
* Expire in 200 ms for 4 (transfer 0x5597284c30)
* Connected to nextcloud.unclaimed.space (51.148.129.254) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: none
  CApath: /etc/ssl/certs
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
*  subject: CN=nextcloud.unclaimed.space
*  start date: Mar 10 17:45:43 2021 GMT
*  expire date: Jun  8 17:45:43 2021 GMT
*  subjectAltName: host "nextcloud.unclaimed.space" matched cert's "nextcloud.unclaimed.space"
* Using Stream ID: 1 (easy handle 0x5597284c30)
> GET / HTTP/2
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Mon, 15 Mar 2021 12:38:55 GMT
* Connection #0 to host nextcloud.unclaimed.space left intact
The error that seems to matter is the HTTP/2 502, but where should I be looking for clues about that?
A 502 means Caddy couldn’t communicate with the upstream proxy. Your logs will confirm this. Are you sure Caddy can reach that service on that IP address and port?
No: it can’t. It seems that nothing can, including curl from the machine that nextcloud is running from. I will investigate the nextcloud server and come back. But thank you for your help and patience.
Thrashing around in confusion I had somehow managed to set nextcloud listening to port 80 and caddy proxying to port 81. Working now, though. There were also errors in the nextcloud config.php, but these weren’t being logged. Only by trying the 'Nextcloud.occ" commands did I see debuggable feedback – a tip I leave in case anyone else has similar problems after hand editing the config.php in a snap.
I only have one further question: where should the header Strict-Transport-Security line go? For the moment it is commented out, for when I put it outside a location block the caddyfile is rejected.
And in any case, I’d just like to say again thank you for your help and patience. So many help forums are full of snark and idiocy and my experience here has been entirely different. Any idiocy in this thread I bought to it myself!
What do you mean by “location block”? What did you actually try, i.e. what did your Caddyfile look like?
I was saying that you should use the header directive:
:grin:
