Nextcloud behind apache to caddy
Moved an existing nextcloud instance to a new server. Have caddy running on another server, both have local lan access and internet traffic is routed to caddy. I have it working except I’d like to modify the url presented to the browser. Found several github and caddy forum entries that detail caddy v1 rewrites needed… i can’t seem to figure out how to translate those to v2 or if they’re even needed now.
right now it comes back https://sub.mycompany.com/index.php/apps/dashboard/#/
It should be: https://sub.mycompany.com/apps/dashboard/
trying to use apache to rewrite causes too many redirects error.
should the nextcloud instance be given an internal hostname resolvable by internal dns so it can pass it’s rewrites back to caddy?
Sep 28 13:14:19 stcontainer caddy[32483]: {"level":"debug","ts":1695906859.6796849,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.3.32:8080","total_upstreams":1}
Sep 28 13:14:19 stcontainer caddy[32483]: {"level":"debug","ts":1695906859.766926,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.3.32:8080","duration":0.08710551,"request":{"remote_ip":"74.115.129.21","remote_port":"17859","client_ip":"74.115.129.21","proto":"HTTP/1.1","method":"PROPFIND","host":"files.mycompany.com","uri":"/remote.php/dav/files/monica/Documents","headers":{"Authorization":[],"Accept":["*/*"],"Cookie":[],"Content-Length":["105"],"X-Forwarded-Host":["files.mycompany.com"],"Accept-Encoding":["gzip, deflate"],"Content-Type":["text/xml; charset=utf-8"],"X-Request-Id":["73913f09-6945-4468-9e17-252e0784961e"],"User-Agent":["Mozilla/5.0 (Macintosh) mirall/2.5.1final (build 20181204) (Nextcloud)"],"Accept-Language":["en-US,*"],"Depth":["0"],"X-Forwarded-For":["74.115.129.21"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":771,"cipher_suite":49195,"proto":"","server_name":"files.mycompany.com"}},"headers":{"Date":["Thu, 28 Sep 2023 13:14:19 GMT"],"Server":["Apache/2.4.52 (Ubuntu)"],"Cache-Control":["no-store, no-cache, must-revalidate"],"Pragma":["no-cache"],"Content-Security-Policy":["default-src 'none';"],"Referrer-Policy":["no-referrer"],"X-Content-Type-Options":["nosniff"],"X-Debug-Token":["5fKlMNThMlABEdKwJnki"],"X-Frame-Options":["SAMEORIGIN"],"X-Permitted-Cross-Domain-Policies":["none"],"X-Xss-Protection":["1; mode=block"],"Dav":["1, 3, extended-mkcol, access-control, calendarserver-principal-property-search, nextcloud-checksum-update, nc-calendar-search, nc-enable-birthday-calendar"],"X-Request-Id":["5fKlMNThMlABEdKwJnki"],"Content-Encoding":["gzip"],"Content-Type":["application/xml; charset=utf-8"],"Expires":["Thu, 19 Nov 1981 08:52:00 GMT"],"X-Robots-Tag":["noindex, nofollow"],"Vary":["Brief,Prefer"],"Content-Length":["243"]},"status":207}
Sep 28 13:14:19 stcontainer caddy[32483]: {"level":"debug","ts":1695906859.805926,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.3.32:8080","total_upstreams":1}
ubuntu 22.04 lts apt repo
Nextcloud server - ubuntu 22.04lts, apache 2.4, 192.168.3.32
Caddy server ubuntu 22.04lts, docker, 192.168.3.37
# /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
version: "3.9"
    image: caddy:2.7.4-alpine
      - "443:443/udp"
      - ./site:/srv
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
# domain name.
#files.mycompany.com {
#	header Strict-Transport-Security max-age=31536000;
#	reverse_proxy 192.168.3.32:8080
	rewrite / /
This seemed to be in the direction i needed to head:
not sure if this one applies… seemed promising at first.
Since Apache is the one handling PHP, you should configure any rewrites there, not in Caddy.
i thought so too but turning on the rewrite engine in the vhost file causes the “too many redirects error”. Is it because the nextcloud vhost file and it’s conf file have rewrites for the same domain name in the caddy file?
It’s probably trying to redirect to HTTPS when Caddy is already terminating TLS and it proxying over HTTP. Or something like that. Ultimately it’s an Apache misconfiguration, not a Caddy problem.
https is turned off in the vhost file.
<VirtualHost *:8080>
    #ServerName files.mycompany.com
    DocumentRoot /var/www/html/nc.mycompany.com
    #ServerAlias files.mycompany.com
    ErrorLog /var/log/apache2/nc_error.log
    CustomLog /var/log/apache2/nc_requests.log combined
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =files.mycompany.com
#RewriteRule ^ http://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
Alias /nextcloud "/var/www/html/nc.mycompany.com/"
<Directory /var/www/html/file.shafertech.io/>
 Options +FollowSymlinks
 AllowOverride All
<IfModule mod_dav.c>
 Dav off
 </IfModule>
SetEnv HOME /var/www/html/nc.mycompany.com
 SetEnv HTTP_HOME /var/www/html/nc.mycompany.com
</Directory>
For anyone else that is using apache to host nextcloud on one server, and another server running caddy reverse proxy here was my answer:
The answer was in the URL in the vhost file. Since i had moved an instance that was a standalone vm to behind a reverse proxy, the vhost file needed changed. I change the *:8080 to files.internal.site:8080 and the redirects in the vhost file to use that internal domain.
Add the reverse proxy entries Next cloud calls for in the config.php. I needed
‘overwrite.cli.url’, ‘overwritehost’ => files.mycompany.com, and trusted_proxies array (use the trusted_domains array as an example if you need one. I simply added the proxy host internal Ip.
the last problem i had is apache was ignoring the .htaccess file. That’s because in ubuntu 22.04 lts it loads the apache2.conf file first and the directory entry for /var/www has allow override none. Changing it to allow overrides for just that entry fixed my last issue.
It started working. the end.
