Need help with try files
Some of the pages I want to access just show failed. even if I use try_files.
For example
in my directory root I have the files
docs/Terraform/naming-convention/index.html
en/docs/Terraform/naming-convention/index.html
Accessing to
https://localhost/en/docs/Terraform/naming-convention FAILED
https://localhost/docs/Terraform/naming-convention WORKS
Installing and running using docker, I use the docker image caddy:2-alpine
Docker
docker run ...
{$DOCUSAURUS_DOMAIN:localhost} {
  root * /var/docusaurus
  try_files {path} /index.html
What do you mean by “failed”? Enable the debug global option. Show your logs. Show example requests with curl -v. Show evidence. Completely fill out the help topic template as per the forum rules. Don’t skip any section. Since you’re running in Docker, show how you run Caddy (docker-compose.yml or whatever).
