1. Bundled script and css of React.js files keeps loading, script that resides inside the head tag of html file. Below is the setup.
**Dockerfile:**
// Stage 1: Build React application
// Stage 2: Serve React application with Caddy
FROM caddy:latest
COPY --from=build /app/frontend/dist /srv
**docker-compose.yml**
version: "3.9"
frontend:
build:
context: ./frontend
dockerfile: Dockerfile
restart: always
image: caddy
- ./frontend/caddy/Caddyfile:/etc/caddy/Caddyfile
**Caddyfile**
email ####@###.com
servers {
timeouts {
read_body 2m
read_header 2m
write 2m
idle 5m
####.####.com {
#api
handle /api/* {
reverse_proxy backendapi:3000 {
read_timeout 1m
write_timeout 1m
# react app
handle /* {
root * /srv
try_files {path} /index.html
Caddy version v2.6.4
Os- Linux
