1. Caddy version (caddy version): 2.5.0
Running Caddy on a TrueNAS (FreeBSD) system running os version 13.0-RELEASE. Jail is running FeeBSD 13.1-RC6. Jail has a dedicated IP address on my internal network, and is in the DMZ on my router for that IP.
I have two domains with Dynamic DNS entries pointing to my router:
Domain #1 => Dyn.com domain, works fine when browsed to. I am looking to move away from this, and use #2 below.
Domain #2 => Namecheap domain, resolves to the same IP, but I get an SSL error when I try to browse to http(s)://www.aiskon.com
TrueNAS-13.0-RELEASE host, Caddy is in a FreeBSD 13.1-RC6 jail, created by a script from DanB35.
(No commands used, caddy created by script)
(None)
email gjschaller@gmail.com
aiskon.net, gjschaller.homeftp.net {
root * /usr/local/www/html
Browsing to #1 works as intended.
Browsing to #2 results in a SSL Protocol error.
root@caddy:~ # curl -v www.aiskon.net
* Trying 69.248.166.7:80...
* Connected to www.aiskon.net (69.248.166.7) port 80 (#0)
> GET / HTTP/1.1
> Host: www.aiskon.net
> User-Agent: curl/7.83.1
< Connection: close
< Location: https://www.aiskon.net/
< Server: Caddy
< Date: Sat, 21 May 2022 20:55:01 GMT
< Content-Length: 0
* Closing connection 0
- Recreated Caddy jail from scratch
- Recreated Caddyfile from scratch
- Pinged & browsed both sites from internally and externally, ensured they had matching IP addresses
Caddy Jail (Server) created using: GitHub - danb35/freenas-iocage-caddy: Script to install Caddy V2 in a FreeNAS jail · GitHub
Hosted URLs:
https://gjschaller.homeftp.net
Thank you for your guidance and help!
