1. Caddy version (v2.5.2):
i follow tutorial here for installation Install — Caddy Documentation
Armbian (debian) bullseye armv71 5.15.25-rk322x
Paste command here.
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"match": [
"host": [
"user.mysite.ml",
"192.168.1.180",
"localhost",
"127.0.0.1",
"usertcp443.mysite.ml"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "vars",
"root": "/var/www/nextcloud"
"encodings": {
"gzip": {}
"handler": "encode",
"prefer": [
"gzip"
"handle": [
"handler": "static_response",
"headers": {
"Location": [
"{http.request.uri.path}/"
"status_code": 308
"match": [
"file": {
"try_files": [
"{http.request.uri.path}/index.php"
"not": [
"path": [
"handle": [
"handler": "rewrite",
"uri": "{http.matchers.file.relative}"
"match": [
"file": {
"split_path": [
".php"
"try_files": [
"{http.request.uri.path}",
"{http.request.uri.path}/index.php",
"index.php"
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"host": "https://localhost:8080"
"transport": {
"protocol": "fastcgi",
"split_path": [
".php"
"upstreams": [
"dial": "unix//run/php/php8.0-fpm.sock"
"match": [
"path": [
"*.php"
"handle": [
"handler": "file_server",
"hide": [
"/etc/caddy/Caddyfile"
"terminal": true
im install nextcloud with caddy, i want use my domain with reverse proxy on my server. when i open my domain i got “This page isn’t working”(On browser) and got “your connection to this site is not secure”(On left url box) . Before that i try openmediavault with apache its working fine. But on caddy i got this problem also i confused about this reverse proxy config. Can anyone help me?
when i try curl i got this
* ALPN, offering h2
* ALPN, offering http/1.1
* CApath: /etc/ssl/certs
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
* ALPN, server accepted to use http/1.1
* subject: CN=usertcp443.x.ml
* start date: Jul 22 16:19:10 2022 GMT
* expire date: Oct 20 16:19:09 2022 GMT
* subjectAltName: host "usertcp443.x.ml" matched cert's "usertcp443.x.ml"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
> GET / HTTP/1.1
> Host: usertcp443.x.ml
> User-Agent: curl/7.74.0
* TLSv1.3 (IN), TLS alert, close notify (256):
* Empty reply from server
* Closing connection 0
* TLSv1.3 (OUT), TLS alert, close notify (256):
curl: (52) Empty reply from server
Sorry i need censored my ip and my domain in curl result
About some installation and config i just follow here:
https://www.vultr.com/docs/how-to-install-nextcloud-on-ubuntu-17-04/
