Need help setting up Caddy with Crowdsec
Caddy crashes once I try to run it with new Crowdsec settings.
```Error: loading initial config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading handler modules: position 1: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading handler modules: position 0: loading module 'crowdsec': provision http.handlers.crowdsec: getting crowdsec app: loading crowdsec app module: crowdsec: invalid configuration: crowdsec API key must not be empty
Made use of prebuild Docker image of Caddy with Geoipblocking and Crowdsec bouncer modules installed.
Source: caddy-custom-builds/caddy-crowdsec-geoip at main · serfriz/caddy-custom-builds · GitHub
Host is Ubuntu desk’top
```services:
    image: serfriz/caddy-crowdsec-geoip:latest
    cap_add:
      - NET_ADMIN
      - 443:443
      - 443:443/udp
      - crowdsec_net
      - /srv/dockerfiles/caddy/data:/data
      - /srv/dockerfiles/caddy/config:/config
      - /srv/dockerfiles/caddy/site:/usr/share/caddy
      - /srv/dockerfiles/caddy/config/Caddyfile:/etc/caddy/Caddyfile
      - /var/log/caddy:/logs
      - /srv/dockerfiles/caddy/geoip:/usr/share/geoip
  crowdsec:
    image: docker.io/crowdsecurity/crowdsec:latest
    container_name: crowdsec
    security_opt:
      - no-new-privileges=true
      - 127.0.0.1:8081:8080
      - crowdsec_net
      - TZ=Europe/Amsterdam
      - GID=1000
      - COLLECTIONS=crowdsecurity/caddy crowdsecurity/http-cve crowdsecurity/wh>
      - BOUNCER_KEY_CADDY=DbwkKQVqiwZeu6JqtmshCy0fgnDTiygZ
      - /srv/dockerfiles/crowdsec/crowdsec-db:/var/lib/crowdsec/data
      - /srv/dockerfiles/crowdsec/crowdsec-config:/etc/crowdsec
      - /srv/dockerfiles/crowdsec/acquis/acquis.yaml:/etc/crowdsec/acquis.yaml
      - /var/log/caddy:/var/log/caddy:ro
  crowdsec_net:
    driver: bridge
    email ralph1212@live.nl
    admin localhost:2019
  debug  # makes Caddy logs more detailed (optional)
  order crowdsec first  # forces the CrowdSec directive to be executed first
  crowdsec {
    api_url http://crowdsec:8080  # it should point to your CrowdSec API (it can be a remote URL)
    api_key DbwkKQVqiwZeu6JqtmshCy0fgnDTiygZ
    ticker_interval 15s
    #disable_streaming
    #enable_hard_fails
kastroe.dedyn.io {
    encode gzip zstd
    # Restrictive TLS-settings
        protocols tls1.2 tls1.3
        ciphers TLS_AES_128_GCM_SHA256 TLS_AES_256_GCM_SHA384
    # Hide server header
    header Server ""
    # --- GEOIP FILTER ---
    # Matcher only Allow NL IPs
    @nl_only {
        maxmind_geolocation {
            db_path "/usr/share/geoip/GeoLite2-Country.mmdb"
            allow_countries NL
    # Allow only NL IPs to Jellyfin
    handle @nl_only {
        reverse_proxy 100.104.224.57:8096 {
            # streaming optimalization Jellyfin
            flush_interval -1
                read_timeout 30s
                write_timeout 30s
                dial_timeout 10s
    # --- STEALTH DROP FOR NON-NL IPs ---
        abort
    # security headers
        X-Frame-Options "DENY"
        Referrer-Policy "no-referrer"
        Permissions-Policy "geolocation=(), microphone=(), camera=()"
    # log settings
        output file /logs/caddy_access.log {
            roll_size 50mb
            roll_keep 5
            roll_keep_for 720h
        format json
