Need Help in Rewriting Rules
caddy:latest
docker in debian
docker-compose up -d
# On indique quel sera le dossier racine du serveur web
root * /srv
php_fastcgi php:9000
encode gzip zstd
#Règle de réécriture
#RewriteRule ^accueil.* /solutions/index.php
rewrite /accueil.* /solutions/index.php
#RewriteRule .*f([0-9]+).html /solutions/folder.php?folid=$1 [L]
rewrite /.*f([0-9]+).html /solutions/folder.php?folid={1}
#RewriteRule .*recherche-de-formation.html /solutions/searchstage.php [L]
rewrite /.*recherche-de-formation.html /solutions/searchstage.php
#RewriteRule .*dossier-([0-9]+)-(.*).html /$2f$1.html [R=permanent,L]
rewrite /.*dossier-([0-9]+)-(.*).html /{2f}{1}.html [R=permanent,L]
#RewriteCond %{REQUEST_URI} /data/
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{HTTP_HOST} ^formation.example.fr$ [NC]
#RewriteRule ^(.*)$ https://formations.example.fr%{REQUEST_URI} [R=301,L]
Hi, I need help with rewriting rules in Caddy. I try to rewrite these rules from htaccess (lines with # are from .htaccess):
rewrite /accueil.* /solutions/index.php → dunno how replace the ^
rewrite /.*f([0-9]+).html /solutions/folder.php?folid={1} –>dunno if it is correct
rewrite /.*recherche-de-formation.html /solutions/searchstage.php –>dunno if it is correct
#RewriteRule .dossier-([0-9]+)-(.).html /$2f$1.html [R=permanent,L]
rewrite /.dossier-([0-9]+)-(.).html /{2f}{1}.html –>dunno if it is correct
And for these 4 next lines, I dunno how to process
Could you help me please ? i am a newby in Caddy and specially in rewriting rules.
Thx in advance,
Micka
no error messages
It is indicated in number 3
and this site with this guy :
Hi again for the 3 first rules it is OK.
But always need help for these ones
#RewriteRule .dossier-([0-9]+)-(. ).html /$2f$1.html [R=permanent,L] –>dunno how to put the R=permanent
#RewriteRule .exmpless-domaine-([0-9]+)-..html /solutions/recherche-de-examples.html?theme=$1 [R=permanent,L]
#RewriteCond %{REQUEST_URI} /back/..(jpg|png|jpeg|pdf)$
#RewriteCond %{HTTP_HOST} ^formation.examples.fr$ [NC]
#RewriteRule ^(.
)$ https://formations.examples.fr%{REQUEST_URI} [R=301,L]
Thanks for your help.
Micka
You need to use named matchers to define path_regexp matchers, that you can then apply to your rewrite directives.
See the docs for matcher syntax, and look at the path_regexp section on the same page to see how to use capture group placeholders.
Thx for your answer. I do this for the other ones.
but for one like this :slight_smile:
RewriteCond %{HTTP_HOST} ^formation.examples.fr$ [NC]*
I don´t knpw how to translate.
That might be a host matcher. But it’s unclear what that does, really. You probably don’t need that at all, because the host is already being matched by the site address.
Hello Francis,
Thanks for you answers :slight_smile:
I try to complete my Caddyfile and it seems to be ok. “seems” because when I browse the website https://docker.neosaiyan.fr I have a lot of redirection 302. Do you know if i mistake in my caddyfile ?
Maybe there is a way to clean cache (php ou caddy) ? I say that because if I delete all the rewriterules caddy redirect on {uri]accueil.html
thanks for your help.
here the start of my caddyfile:
	email mgagnant@neosaiyan.fr
	#HTTP/3 support
	servers {
		protocol {
			experimental_http3
docker.neosaiyan.fr {
	root * /srv
	encode gzip zstd
	#Règle de réécriture de l’accueil
	@accueil path_regexp accueil ^/accueil.*
	rewrite @accueil /solutions/index.php
	#Règle de réécriture des dossiers
	@solfolder path_regexp solfolder .*f([0-9]+).html
	rewrite @solfolder /solutions/folder.php?folid={re.solfolder.1}
I have another rewrite rules in caddyfile btw
Thx for your help
Micka.
What do you see when you make the request with curl -v? It will show the headers of the response, which will help with seeing what’s going on.
Also, what’s in your logs? Turn on the debug global option (put it before email) to see more details in the logs.
thx for your reply Francis,
here is my curl -v
  • Trying 85.170.255.241:443…
  • Connected to docker.neosaiyan.fr (85.170.255.241) port 443 (#0)
  • ALPN, offering h2
  • ALPN, offering http/1.1
  • successfully set certificate verify locations:
  • CAfile: /etc/ssl/certs/ca-certificates.crt
  • CApath: /etc/ssl/certs
  • TLSv1.3 (OUT), TLS handshake, Client hello (1):
  • TLSv1.3 (IN), TLS handshake, Server hello (2):
  • TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
  • TLSv1.3 (IN), TLS handshake, Certificate (11):
  • TLSv1.3 (IN), TLS handshake, CERT verify (15):
  • TLSv1.3 (IN), TLS handshake, Finished (20):
  • TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
  • TLSv1.3 (OUT), TLS handshake, Finished (20):
  • SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256
  • ALPN, server accepted to use h2
  • Server certificate:
  • subject: CN=docker.neosaiyan.fr
  • start date: Jul 26 09:02:51 2022 GMT
  • expire date: Oct 24 09:02:50 2022 GMT
  • subjectAltName: host “docker.neosaiyan.fr” matched cert’s “docker.neosaiyan.fr
  • issuer: C=US; O=Let’s Encrypt; CN=R3
  • SSL certificate verify ok.
  • Using HTTP2, server supports multi-use
  • Connection state changed (HTTP/2 confirmed)
  • Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
  • Using Stream ID: 1 (easy handle 0x5590d90905c0)
GET / HTTP/2
Host: docker.neosaiyan.fr
user-agent: curl/7.74.0
accept: /
  • TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
  • Connection state changed (MAX_CONCURRENT_STREAMS == 250)!
    < HTTP/2 302
    < alt-svc: h3=“:443”; ma=2592000,h3-29=“:443”; ma=2592000
    < content-type: text/html; charset=UTF-8
    < location: ./accueil.html
    < server: Caddy
    < status: 302 Found
    < x-powered-by: PHP/7.4.30
    < content-length: 0
    < date: Tue, 26 Jul 2022 14:50:49 GMT
  • Connection #0 to host docker.neosaiyan.fr left intact
in logs I have many response like this :slight_smile: {“level”:“info”,“ts”:1658847127.1332803,“logger”:“http.log.access”,“msg”:“handled request”,“request”:{“remote_ip”:“91.167.58.35”,“remote_port”:“28818”,“proto”:“HTTP/2.0”,“method”:“GET”,“host”:“docker.neosaiyan.fr”,“uri”:“/css/materialize/accueil.html”,“headers”:{“Sec-Fetch-Mode”:[“navigate”],“Accept-Encoding”:[“gzip, deflate, br”],“Cache-Control”:[“max-age=0”],“User-Agent”:[“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36”],“Accept”:[“text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9”],“Sec-Fetch-Dest”:[“document”],“Sec-Ch-Ua”:[“".Not/A)Brand";v="99", "Google Chrome";v="103", "Chromium";v="103"”],“Accept-Language”:[“fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7”],“Cookie”:,“Sec-Fetch-User”:[“?1”],“Sec-Ch-Ua-Mobile”:[“?0”],“Sec-Ch-Ua-Platform”:[“"Windows"”],“Upgrade-Insecure-Requests”:[“1”],“Sec-Fetch-Site”:[“none”]},“tls”:{“resumed”:true,“version”:772,“cipher_suite”:4865,“proto”:“h2”,“server_name”:“docker.neosaiyan.fr”}},“user_id”:“”,“duration”:0.012834906,“size”:0,“status”:302,“resp_headers”:{“X-Powered-By”:[“PHP/7.4.30”],“Location”:[“./accueil.html”],“Content-Type”:[“text/html; charset=UTF-8”],“Server”:[“Caddy”],“Alt-Svc”:[“h3=":443"; ma=2592000,h3-29=":443"; ma=2592000”],“Status”:[“302 Found”]}}
This tells me the redirect is coming from your PHP app, not from Caddy.
You’ll need to dig into what the app is doing that would cause the redirect.
Ok Thanks Francis,
I will investigate in php
