. Caddy version:
2.6.2
Ubuntu 22.04.1 LTS (jammy) on Upcloud
rptest.aaa.com {
reverse_proxy * {
to http://152.44.1.1 http://209.50.1.2
fail_duration 1d
max_fails 1
I’m trying to implement ALL downstream requests going to the 2nd server once the first server is unhealthy.
Using the config shown above, it appears to be load balancing - I can see BOTH servers getting traffic, not just the first one listed.
I dont want that.
I don’t need load balancing.
I’m trying to create a failover server in the event 1st server has an issue.
I think my config is using “passive health checking”, per the docs.
I could use Active as well - I have a static URL I could hit on the primary server to see if it gets a response.
I don’t see any code examples for this use case.
thx
