Need help converting Free Fat Framework .htaccess file to Caddy rewrite
Hello, I need help converting below Free Fat Framework .htaccess file over to Caddy rewrite.
I am using Caddy 0.8.3
Enable rewrite engine and route requests to framework
RewriteEngine On
Some servers require you to specify the RewriteBase directive
In such cases, it should be the path (relative to the document root)
containing this .htaccess file
RewriteCond %{REQUEST_URI} .ini$
RewriteRule .ini$ - [R=404]
RewriteCond %{REQUEST_FILENAME} !-l
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule .* index.php [L,QSA]
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization},L]
Thank you and a nice day.
Hey Chris, please format your post using backticks (`) on their own line for the code blocks. Thanks
Try the following, it’s for Laravel but I think it will work:
rewrite {
        r .*
        ext /
        to /index.php?{query}
Taken from:
Hi Nixtren, the rewrite worked for the Fat-Free Framework, million thanks :smiley:
