Need help configuring caddy with vps (ubuntu)
v2.6.4
installed from the command line using sudo apt install caddy
Ubuntu 20, VPS (CLI only), no docker
b. My complete Caddyfile or JSON config:
No config file, trying to do the ONE LINER reverse proxy method
caddy cannot startup on port 80, tells me something else is already on port 80 (but I can’t figure out what)
`caddy reverse-proxy --from (domain name) --to 127.0.0.1:8096
2023/07/30 11:40:45.430 WARN    admin   admin endpoint disabled
2023/07/30 11:40:45.432 INFO    http    server is listening only on the HTTPS po                    rt but has no TLS connection policies; adding one to enable TLS {"server_name":                     "proxy", "https_port": 443}
2023/07/30 11:40:45.433 INFO    http    enabling automatic HTTP->HTTPS redirects                    {"server_name": "proxy"}
2023/07/30 11:40:45.436 INFO    tls     cleaning storage unit   {"description":                     "FileStorage:/home/jellyfin/.local/share/caddy"}
2023/07/30 11:40:45.437 INFO    tls     finished cleaning storage units
2023/07/30 11:40:45.433 INFO    tls.cache.maintenance   started background certi                    ficate maintenance      {"cache": "0xc0002f8f50"}
2023/07/30 11:40:45.438 INFO    tls.cache.maintenance   stopped background certi                    ficate maintenance      {"cache": "0xc0002f8f50"}
Error: loading new config: http app module: start: listening on :443: listen tcp                     :443: bind: permission denied
Caddy itself is probably already running as a systemd service. See Keep Caddy Running — Caddy Documentation for instructions for using Caddy as a service.
