Look for it.marcelsoftware.dev
Nov 24 10:37:41 ubuntu systemd[1]: Starting Caddy...
Nov 24 10:37:41 ubuntu caddy[1649363]: caddy.HomeDir=/var/lib/caddy
Nov 24 10:37:41 ubuntu caddy[1649363]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Nov 24 10:37:41 ubuntu caddy[1649363]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Nov 24 10:37:41 ubuntu caddy[1649363]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Nov 24 10:37:41 ubuntu caddy[1649363]: caddy.Version=v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
Nov 24 10:37:41 ubuntu caddy[1649363]: runtime.GOOS=linux
Nov 24 10:37:41 ubuntu caddy[1649363]: runtime.GOARCH=amd64
Nov 24 10:37:41 ubuntu caddy[1649363]: runtime.Compiler=gc
Nov 24 10:37:41 ubuntu caddy[1649363]: runtime.NumCPU=4
Nov 24 10:37:41 ubuntu caddy[1649363]: runtime.GOMAXPROCS=4
Nov 24 10:37:41 ubuntu caddy[1649363]: runtime.Version=go1.23.3
Nov 24 10:37:41 ubuntu caddy[1649363]: os.Getwd=/
Nov 24 10:37:41 ubuntu caddy[1649363]: LANG=C.UTF-8
Nov 24 10:37:41 ubuntu caddy[1649363]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Nov 24 10:37:41 ubuntu caddy[1649363]: NOTIFY_SOCKET=/run/systemd/notify
Nov 24 10:37:41 ubuntu caddy[1649363]: HOME=/var/lib/caddy
Nov 24 10:37:41 ubuntu caddy[1649363]: LOGNAME=caddy
Nov 24 10:37:41 ubuntu caddy[1649363]: USER=caddy
Nov 24 10:37:41 ubuntu caddy[1649363]: INVOCATION_ID=27ec395fa98b4056b83de21509b2f240
Nov 24 10:37:41 ubuntu caddy[1649363]: JOURNAL_STREAM=8:20948905
Nov 24 10:37:41 ubuntu caddy[1649363]: SYSTEMD_EXEC_PID=1649363
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.656575,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6620166,"msg":"adapted config to JSON","adapter":"caddyfile"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"warn","ts":1732444661.6620474,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":4}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6645129,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6654088,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc001cb7800"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6656353,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6656737,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6657386,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["gptproxy.marcelsoftware.dev","docker.marcelsoftware.dev","twenty.marcelsoftware.dev","unami.marcelsoftware.dev","stats.marcelsoftware.dev","auth.marcelsoftware.dev","gpt.marcelsoftware.dev","marcelsoftware.dev"]},{"subjects":["mail.marcelsoftware.dev"],"key_type":"rsa2048"},{"subjects":["git.marcelsoftware.dev"],"on_demand":true},{"subjects":["it.marcelsoftware.dev"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:8121"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:9000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:3000"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":":3001"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"authentication","providers":{"authorizer":{"gatekeeper_name":"admins_policy","route_matcher":"*"}}},{"handler":"reverse_proxy","upstreams":[{"dial":":61208"}]}]}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"body":"Hello DMS","handler":"static_response"}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"authenticator","portal_name":"myportal","route_matcher":"*"}]}]}],"match":[{"path":["*"]}]}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:6610"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:3080"}]}]}]}],"terminal":true},{"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"vars","root":"/var/opt/www"},{"handler":"file_server","hide":["/etc/caddy/Caddyfile"]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6677454,"logger":"security","msg":"provisioning app instance","app":"security"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.66791,"logger":"security","msg":"identity store authenticator configuration","kind":"local","db_path":"/var/lib/caddy/users.json"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.670907,"logger":"security","msg":"successfully configured identity store","name":"localdb","kind":"local","db_path":"/var/lib/caddy/users.json","login_icon":{"class_name":"las la-key la-2x","color":"white","background_color":"#324960","text_color":"#37474f"}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6710112,"logger":"security","msg":"Configuring caching","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.671116,"logger":"security","msg":"Configuring cookie parameters","portal_name":"myportal","cookie_config":{"domains":{"marcelsoftware.dev":{"seq":1,"domain":"marcelsoftware.dev"}}}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.671176,"logger":"security","msg":"Configuring default portal user roles","portal_name":"myportal","portal_admin_roles":{"authp/admin":true},"portal_user_roles":{"authp/user":true},"portal_guest_roles":{"authp/guest":true},"portal_admin_role_patterns":[],"portal_user_role_patterns":[],"portal_guest_role_patterns":[]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6712103,"logger":"security","msg":"Configuring authentication ACL","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8","access_list_configs":[{"comment":"admin role name match","conditions":["match role authp/admin"],"action":"allow stop"},{"comment":"user role name match","conditions":["match role authp/user"],"action":"allow stop"},{"comment":"guest role name match","conditions":["match role authp/guest"],"action":"allow stop"}]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6713378,"logger":"security","msg":"Configured validator ACL","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8","token_validator_options":{"validate_bearer_header":true},"token_grantor_options":{}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.671367,"logger":"security","msg":"Configuring identity store login options","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8","identity_store_count":1}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.671431,"logger":"security","msg":"Provisioned login options","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8","options":{"authenticators":[{"background_color":"#324960","class_name":"las la-key la-2x","color":"white","realm":"local","text":"LOCAL","text_color":"#37474f"}],"authenticators_required":"no","default_realm":"local","form_required":"yes","hide_contact_support_link":"yes","hide_forgot_username_link":"yes","hide_links":"yes","hide_register_link":"yes","identity_required":"yes","realm_dropdown_required":"no","realms":[{"default":"yes","label":"LOCAL","realm":"local"}]},"identity_store_count":1,"identity_provider_count":0}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.671511,"logger":"security","msg":"Configuring user interface","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6717153,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"login"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6724749,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"sandbox"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6734333,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"apps_sso"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6736794,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"apps_mobile_access"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6738484,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"portal"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.674025,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"whoami"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.674191,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"register"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6746094,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"generic"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6747975,"logger":"security","msg":"Configuring default authentication user interface templates","portal_name":"myportal","template_theme":"basic","template_name":"settings"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.677312,"logger":"security","msg":"Configured user interface","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8","title":"Sign In","logo_url":"/assets/images/logo.svg","logo_description":"Authentication Portal","action_endpoint":"","private_links":[{"link":"https://marcelsoftware.dev/","title":"My Website","icon_name":"las la-star","icon_enabled":true},{"link":"/whoami","title":"My Identity","icon_name":"las la-user","icon_enabled":true}],"realms":[],"theme":"basic"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.677373,"logger":"security","msg":"Configuring user transforms","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6774652,"logger":"security","msg":"Configured user transforms","portal_name":"myportal","portal_id":"64339144-8afd-44cb-8d63-913dfab88bd8","transforms":[{"matchers":["exact match origin local"],"actions":["action add role authp/user","ui link \"Portal Settings\" /settings icon \"las la-cog\""]}]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6774905,"logger":"security","msg":"Logout redirect URI configuration not present"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.678099,"logger":"security","msg":"Configured gatekeeper","gatekeeper_name":"admins_policy","gatekeeper_id":"ef8465f0-63d0-4a45-b1d0-38159b0acc43","auth_url_path":"https://auth.marcelsoftware.dev/","token_sources":"cookie header query","token_validator_options":{},"access_list_rules":[{"conditions":["match roles authp/admin authp/user"],"action":"allow log debug"},{"comment":"comment allow users","conditions":["match role authp/user"],"action":"allow stop log info"},{"comment":"comment default deny","conditions":["match any"],"action":"deny log warn"}],"forbidden_path":""}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6781573,"logger":"security","msg":"provisioned app instance","app":"security"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6792707,"logger":"security","msg":"started app instance","app":"security"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6795483,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6799731,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6800368,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6801307,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.680151,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6801622,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["mail.marcelsoftware.dev","auth.marcelsoftware.dev","it.marcelsoftware.dev","twenty.marcelsoftware.dev","unami.marcelsoftware.dev","stats.marcelsoftware.dev","gptproxy.marcelsoftware.dev","git.marcelsoftware.dev","gpt.marcelsoftware.dev","marcelsoftware.dev","docker.marcelsoftware.dev"]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"warn","ts":1732444661.6816223,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [mail.marcelsoftware.dev]: no OCSP server specified in certificate","identifiers":["mail.marcelsoftware.dev"]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6816883,"logger":"tls.cache","msg":"added certificate to cache","subjects":["mail.marcelsoftware.dev"],"expiration":1732464030,"managed":true,"issuer_key":"local","hash":"c4f0ab6901b2f4a0616440e21ca5c15082cdd7904f0b9947472ef6a0a1da41f0","cache_size":1,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6817436,"logger":"events","msg":"event","name":"cached_managed_cert","id":"e1a6250b-c2e0-4d0e-bf96-a8b1effa0bea","origin":"tls","data":{"sans":["mail.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6827326,"logger":"tls.cache","msg":"added certificate to cache","subjects":["auth.marcelsoftware.dev"],"expiration":1740062167,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"76d27ec29bcfe47cce384381e6059498043f282c08eb60a8d4a7951063f4fb4a","cache_size":2,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6828196,"logger":"events","msg":"event","name":"cached_managed_cert","id":"64f19418-55cc-457c-99bf-60e9b2e1edc0","origin":"tls","data":{"sans":["auth.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6835608,"logger":"tls.cache","msg":"added certificate to cache","subjects":["twenty.marcelsoftware.dev"],"expiration":1739953348,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"be05070585e0357d62778b3705d69f6576b2e5f27cd8b47746500abb86305e42","cache_size":3,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.683628,"logger":"events","msg":"event","name":"cached_managed_cert","id":"7bd78bf6-99d1-4034-8e58-54b8c02750c1","origin":"tls","data":{"sans":["twenty.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6843593,"logger":"tls.cache","msg":"added certificate to cache","subjects":["unami.marcelsoftware.dev"],"expiration":1739969274,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"1e9cf05f2fb774de8d4fba9bd95ee8a13c2f79831b3c20b98fb4c2c446dc4ad3","cache_size":4,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6844327,"logger":"events","msg":"event","name":"cached_managed_cert","id":"2ec9d190-8b50-4f58-b724-27a3f949a18f","origin":"tls","data":{"sans":["unami.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6852264,"logger":"tls.cache","msg":"added certificate to cache","subjects":["stats.marcelsoftware.dev"],"expiration":1739744142,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"b0d429e9b3480d97d1d5e948b573410f9a450eefe7f8d13c4293c607da1e8ed0","cache_size":5,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6853306,"logger":"events","msg":"event","name":"cached_managed_cert","id":"788e8143-11ef-4d3f-9c40-b95e003f01fd","origin":"tls","data":{"sans":["stats.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6861703,"logger":"tls.cache","msg":"added certificate to cache","subjects":["gptproxy.marcelsoftware.dev"],"expiration":1739741628,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"9023cfee1e355dd50369b3ca5940394fce181d681406458d41c3c068bc4903a5","cache_size":6,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6862557,"logger":"events","msg":"event","name":"cached_managed_cert","id":"f85a0b04-c05e-4b8a-b902-48effb6941f1","origin":"tls","data":{"sans":["gptproxy.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6870294,"logger":"tls.cache","msg":"added certificate to cache","subjects":["gpt.marcelsoftware.dev"],"expiration":1739729466,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"5e3f4a4bdd47fdf311de9ecfd3f1ed86583253c02b01934b302080eb36d1fc89","cache_size":7,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6870956,"logger":"events","msg":"event","name":"cached_managed_cert","id":"e338821b-19a2-4308-b273-9bb1b06540c2","origin":"tls","data":{"sans":["gpt.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6879172,"logger":"tls.cache","msg":"added certificate to cache","subjects":["marcelsoftware.dev"],"expiration":1739801101,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"90df7f0afd66107aa3575821d61e75a405ecc023dea08df2b92b1e7d72a7e860","cache_size":8,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.688017,"logger":"events","msg":"event","name":"cached_managed_cert","id":"c2be889a-b7f2-48fd-9554-ee4599eaaaca","origin":"tls","data":{"sans":["marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6887672,"logger":"tls.cache","msg":"added certificate to cache","subjects":["docker.marcelsoftware.dev"],"expiration":1739723181,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"93f387d33d1fca08805ba8311fa926c81e4d7f896aee1248fa79b8a6d0667e9c","cache_size":9,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6888826,"logger":"events","msg":"event","name":"cached_managed_cert","id":"cffac906-d0da-4975-895d-edac1b03e308","origin":"tls","data":{"sans":["docker.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6894522,"logger":"tls","msg":"loading managed certificate","domain":"it.marcelsoftware.dev","expiration":1739724166,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6898935,"logger":"tls.cache","msg":"added certificate to cache","subjects":["it.marcelsoftware.dev"],"expiration":1739724166,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"e89bbf64dc2012254786d0e343569b6498aefb4a626030fb67c3f55bcddccfaa","cache_size":10,"cache_capacity":10000}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6899614,"logger":"events","msg":"event","name":"cached_managed_cert","id":"aec1ef37-891e-4e20-beca-5042c4012222","origin":"tls","data":{"sans":["it.marcelsoftware.dev"]}}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.690113,"logger":"layer4","msg":"listening","address":"tcp/[::]:443"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6901803,"logger":"layer4","msg":"listening","address":"tcp/[::]:22"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6902115,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"debug","ts":1732444661.6903534,"logger":"dynamic_dns","msg":"beginning IP address check"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6904259,"logger":"dynamic_dns","msg":"Loaded dynamic domains","domains":["twenty.marcelsoftware.dev","unami.marcelsoftware.dev","auth.marcelsoftware.dev","gptproxy.marcelsoftware.dev","mail.marcelsoftware.dev","git.marcelsoftware.dev","it.marcelsoftware.dev","marcelsoftware.dev","docker.marcelsoftware.dev","stats.marcelsoftware.dev","gpt.marcelsoftware.dev"]}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.690454,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"twenty"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6904643,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"unami"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6904728,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"auth"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6904824,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"gptproxy"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.69049,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"mail"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6904979,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"git"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6905053,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"it"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6905134,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"@"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6905208,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"docker"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6905303,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"stats"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6905382,"logger":"dynamic_dns","msg":"Adding dynamic domain","domain":"gpt"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.6907032,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Nov 24 10:37:41 ubuntu systemd[1]: Started Caddy.
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.694193,"msg":"serving initial configuration"}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.69791,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"5a891700-d907-4fed-8276-709bd1d5beb8","try_again":1732531061.697907,"try_again_in":86399.999998934}
Nov 24 10:37:41 ubuntu caddy[1649363]: {"level":"info","ts":1732444661.698055,"logger":"tls","msg":"finished cleaning storage units"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0722628,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"auth","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0723314,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"caddy","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0723453,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"docker","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0723553,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"git","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0723648,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"gpt","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0723753,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"gptproxy","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072385,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"it","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0723948,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"mail","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072429,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0724444,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"proton","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0724547,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"smtp","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072465,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"stats","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0724738,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"twenty","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072483,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"umami","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0724938,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"unami","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0725152,"logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"www","zone":"marcelsoftware.dev","value":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0725265,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"auth","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0725381,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"caddy","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072552,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"docker","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072564,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"git","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0725734,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"gpt","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0725832,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"gptproxy","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0725927,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"it","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726018,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"mail","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726106,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726185,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"proton","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726264,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"smtp","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726354,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"stats","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726614,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"twenty","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072672,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"umami","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726814,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"unami","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.0726907,"logger":"dynamic_dns","msg":"found DNS record","type":"AAAA","name":"www","zone":"marcelsoftware.dev","value":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.072768,"logger":"dynamic_dns","msg":"looked up current IPs from DNS","lastIPs":{"auth.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"docker.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"git.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"gpt.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"gptproxy.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"it.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"mail.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"stats.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"twenty.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"unami.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]},"www.marcelsoftware.dev":{"A":["188.241.240.67"],"AAAA":["2a0e:8f02:f04f:1074::"]}}}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.1299486,"logger":"dynamic_dns.ip_sources.simple_http","msg":"lookup","type":"IPv4","endpoint":"https://icanhazip.com","ip":"188.241.240.67"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.1727421,"logger":"dynamic_dns.ip_sources.simple_http","msg":"lookup","type":"IPv6","endpoint":"https://icanhazip.com","ip":"2a0e:8f02:f04f:1074::"}
Nov 24 10:37:43 ubuntu caddy[1649363]: {"level":"debug","ts":1732444663.172859,"logger":"dynamic_dns","msg":"no IP address change; no update needed"}
Nov 24 10:37:50 ubuntu caddy[1649363]: {"level":"debug","ts":1732444670.3211243,"logger":"events","msg":"event","name":"tls_get_certificate","id":"de8dd3fe-8b50-4e3d-8c00-6961b10922ed","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4867,4866,49195,49199,52393,52392,49196,49200,49171,49172,156,157,47,53],"ServerName":"it.marcelsoftware.dev","SupportedCurves":[4588,29,23,24,25,256,257],"SupportedPoints":"AA==","SignatureSchemes":[1027,1283,1539,2052,2053,2054,1025,1281,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"82.77.10.249","Port":60500,"Zone":""},"LocalAddr":{"IP":"188.241.240.67","Port":443,"Zone":""}}}}
Nov 24 10:37:50 ubuntu caddy[1649363]: {"level":"debug","ts":1732444670.3212023,"logger":"tls.handshake","msg":"choosing certificate","identifier":"it.marcelsoftware.dev","num_choices":1}
Nov 24 10:37:50 ubuntu caddy[1649363]: {"level":"debug","ts":1732444670.3212347,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"it.marcelsoftware.dev","subjects":["it.marcelsoftware.dev"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"e89bbf64dc2012254786d0e343569b6498aefb4a626030fb67c3f55bcddccfaa"}
Nov 24 10:37:50 ubuntu caddy[1649363]: {"level":"debug","ts":1732444670.3212512,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"82.77.10.249","remote_port":"60500","subjects":["it.marcelsoftware.dev"],"managed":true,"expiration":1739724166,"hash":"e89bbf64dc2012254786d0e343569b6498aefb4a626030fb67c3f55bcddccfaa"}
