Multiplexing SSH/HTTPS for LAN devices with Caddy L4
Hello guys, I’m trying to multiplex SSH and HTTPS for my LAN network devices, served under the *.home.lan private domain, but I’m banging my head on Caddy L4, and I’m not able to find a way to write a working config. I would like to multiplex router.home.lan and ap.home.lan. I found some code that I added to my config file here, but it’s not working. Do you have any suggestion that can apply to my configuration?
UNRAID 6.12.15, Caddy running through docker.
    # debug
    email johnnymnemonic@gmail.com
    servers {
        client_ip_headers X-Forwarded-For
		listener_wrappers {
			layer4 {
				@ssh_layer4 ssh
				route @ssh_layer4 {
					proxy 192.168.1.1:22 {
				route
			tls
*.home.lan {
    tls internal
    map {labels.2}  {srv_group} {srv_name}          {srv_port} {
        ap          1           192.168.1.2         80
        dns         1           192.168.1.1         3000
        filebot     1           filebot             5800
        files       1           filebrowser         80
        links       1           linkding            9090
        paper       1           paperless-ngx       8000
        photo       1           immich              8080
        plex        1           192.168.1.11        32400
        router      1           192.168.1.1         80
        speed       1           myspeed             5216
        torrent     1           rflood              3000
        vault       1           vaultwarden         80
        zigbee      1           zigbee2mqtt         8080
        webdav      11          -                   -
        cert        12          -                   -
        default     0           -                   -
    # Check request group and create appropriate matcher.
    # The idea is to generalize configuration for the services as much as possible.
    @direct   vars {srv_group} 1
    @webdav   vars {srv_group} 11
    @cert     vars {srv_group} 12
    @error    vars {srv_group} 0
    handle @direct {
        reverse_proxy {srv_name}:{srv_port}
    handle @webdav {
        route {
            basic_auth {
                user $xxxx
            root /srv/webdav
            webdav
    handle @cert {
            Content-Type application/octet-stream
            Content-Disposition `attachment; filename="caddy_root.crt"`
        root * /data/caddy/pki/authorities/local
        rewrite * /root.crt
    handle @error {
        error "Access Denied" 403
i don’t see l4 config in your caddyfile
Oh yeah, I copied the previous version of the file. Basically there is not much documentation on L4, so I followed what I found here, without success. I updated the op.
After some trial and error I was able to write a working configuration. It turned out that multiplexing wasn’t the solution when there are multiple ssh host, because there is no way to address them (no matchers for the layer4 ssh handler). The solution would be to use SSH over TLS, but it requires wrapping the ssh connection with openssl.
This is a simpler alternative, where the listening ports are used to address the connection to the ssh servers, so that we can connect through caddy using ssh -p <port-number> user@fqdn.
    layer4 {
        :2001 {
            @ssh ssh
            route @ssh {
                proxy 192.168.44.1:22
        :2002 {
            @ssh ssh
            route @ssh {
                proxy 192.168.44.2:22
        :2011 {
            @ssh ssh
            route @ssh {
                proxy 192.168.44.11:22
I tried to investigate if there is any placeholder for the listening port, so that we can listen on a port range and use map to switch on the port, but I was not able to find anything… Suggestions?
