Multiple Wildcards - Is it possible?
I want to know if it is possible to use more than one wildcard in a file if you are having it pull the cert automatically using the cloudflare add-on with reverse proxy setup. I have it working with just one wildcard currently.
Example:
I already have *.maindomainA.com wildcard up and running.
Is it possible to add a second wildcard configuration as well?
*.maindomainA.com
*.maindomainB.com
*.maindomainA.com {
		dns cloudflare XXXXXXXXXXXXXXXXXXXXXXXXXX
		resolvers 1.1.1.1
	reverse_proxy /tautulli* 192.168.55.205:8181
	reverse_proxy /radarr* 192.168.55.207:7878
	reverse_proxy /sonarr* 192.168.55.207:8989
	reverse_proxy /info* 192.168.55.205:5960
	reverse_proxy /lidarr* 192.168.55.207:8686
	reverse_proxy 192.168.55.205:5055
	@app host app.maindomainA.com
	handle @app {
		reverse_proxy 192.168.55.205:32400
	import /etc/caddy/caddy_security.conf
Yes
