Installed with apt-get install caddy
and using the default service config (see below)
Ubuntu 20.04
sudo systemctl start caddy
# /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
http://chatdev.blackjackapprenticeship.com:8088 {
reverse_proxy localhost:3039
https://chatdev.blackjackapprenticeship.com {
reverse_proxy localhost:3000
My apps are running correctly on localhost (i.e. I can curl localhost:3000 and localhost:3039 without issue). However, only the default ports (80/443) are returning anything when I run with the above Caddyfile. Why can I not get a response on port 8088 of my domain?
$ curl -v http://chatdev.blackjackapprenticeship.com:8088
* Trying 52.89.109.217:8080...
* TCP_NODELAY set
And it just hangs there until it times out.
From `sudo journalctl -u caddy.service
-- Logs begin at Sun 2021-09-12 01:31:54 UTC. --
Sep 26 08:13:38 ip-172-31-45-81 caddy-with-cloudflare[102200]: {"level":"info","ts":1632644018.6345642,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["chatdev.blackjackapprenticeship.com"]}
Sep 26 08:13:38 ip-172-31-45-81 caddy-with-cloudflare[102200]: {"level":"debug","ts":1632644018.6350524,"logger":"tls","msg":"loading managed certificate","domain":"chatdev.blackjackapprenticeship.com","expiration":1640410680,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Sep 26 08:13:38 ip-172-31-45-81 caddy-with-cloudflare[102200]: {"level":"info","ts":1632644018.6396008,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002c4310"}
Sep 26 08:13:38 ip-172-31-45-81 caddy-with-cloudflare[102200]: {"level":"info","ts":1632644018.6464748,"msg":"autosaved config","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 26 08:13:38 ip-172-31-45-81 caddy-with-cloudflare[102200]: {"level":"info","ts":1632644018.6466293,"msg":"serving initial configuration"}
Sep 26 08:13:38 ip-172-31-45-81 caddy-with-cloudflare[102200]: {"level":"info","ts":1632644018.6476276,"logger":"tls","msg":"cleaned up storage units"}
I’ve tried variations of the address for my first block. It works fine if I use http://localhost:8088
or any other domain, but not the same domain as the second block and I’m restricted on this project to using the same domain. I’ve tried specifying ports explicitly on both like this:
https://chatdev.blackjackapprenticeship.com:443 {
I’ve tried reading through a number of forum posts and documentation from Caddy that all suggest this should work without issue (see One domain multiple ports).
I’m at a loss and any help is appreciated.
