Multiple proxies for same site
Hi! I’m using Caddy to revers proxy some sites on a DigitalOcean Ubuntu droplet.
This is my Caddy file, pretty simple :upside_down:
my-site.com {
  # projects
  proxy /projects/some-project localhost:8998
  # main site
  proxy / localhost:9000
other-site.com {
  proxy / localhost:8999 # main site
my-site.com and other-site.com are working just fine.
But I’m getting a 404 when trying to access my-site.com/projects/some-project. I’ve double checked and localhost:8998 works properly on DO.
my-site.com is a Harp.js app, it is catching all the 404 how it is expected, but /projects/some-project is showing the Caddy default 404 message.
Should I work like I expect? Am I missing something?
I posted the question also on StackOverflow.
I don’t have any idea about your backend, but is it expecting the path to start with /projects/some-project? If not, you need to use this in your proxy directive to strip it:
without /projects/some-project
Thanks for the quick answer! That worked :smile:
