Multiple forward slashes
Hi
I’m trying to use rewrite and status, and I’m having a problem multiple forward slashes. Let’s say I want to protect the path /secret/files and I write in my caddyfile: status 401 /secret/files/. Now I get a 401 when I request /secret/files/.... But Caddy will happily serve //secret/files/... and /secret//files/... and so on. Is there a switch for collapsing multiple forward slashes? Or is this a bug? This also affect rewrite (and probably other path matches)
I was able to replicate the issue with this Caddyfile:
:2015
With the following folder structure:
Matt at hermes in ~/Projects/test
→ exa -lgTL 3
drwxr-xr-x  - Matt staff  7 Sep  9:48 .
.rw-r--r-- 58 Matt staff  7 Sep  9:42 ├── Caddyfile
.rw-r--r-- 20 Matt staff  2 Aug 17:02 ├── index.html
drwxr-xr-x  - Matt staff  7 Sep  9:42 └── secret
drwxr-xr-x  - Matt staff  7 Sep  9:50    └── files
.rw-r--r-- 20 Matt staff  2 Aug 17:02       └── index.html
When requesting //secret/files or /secret//files, I get a 301 to single slashes:
→ curl -iL localhost:2015/secret//files
HTTP/1.1 301 Moved Permanently
Server: Caddy
Date: Wed, 06 Sep 2017 23:51:20 GMT
Content-Length: 49
Content-Type: text/html; charset=utf-8
HTTP/1.1 401 Unauthorized
Server: Caddy
X-Content-Type-Options: nosniff
Content-Length: 17
401 Unauthorized
Requesting the index.html directly fails with single slashes, as expected:
→ curl -i localhost:2015/secret/files/index.html
Server: Caddy
Date: Wed, 06 Sep 2017 23:53:38 GMT
Content-Length: 17
401 Unauthorized
Requesting with double slash in the path matched by status bypasses that status directive entirely:
→ curl -i localhost:2015/secret//files/index.html
HTTP/1.1 200 OK
Accept-Ranges: bytes
Content-Length: 20
Etag: "ou1q7xk"
Last-Modified: Wed, 02 Aug 2017 07:02:21 GMT
Server: Caddy
Date: Wed, 06 Sep 2017 23:54:15 GMT
This is /secret/files/index.html.
Not technically a bug, I suppose - since the request path clearly doesn’t match the path specified by status.
Definitely inconsistent and possibly dangerous, though, requiring ludicrous amounts of Caddyfile syntax to work around. Imagine having to do this for any set of files you care about:
status 401 //path/to/secret/files
status 401 /path//to/secret/files
status 401 /path/to//secret/files
status 401 /path/to/secret//files
status 401 //path//to/secret/files
# ...repeat until 2^n (n = count of path elements)... 11 more permutations!
An excellent candidate for a Github issue if I’ve ever seen one.
This has been and is being discussed at some length here:
https://github.com/mholt/caddy/issues/1859
The correct solution (within Caddy, not referring to the config here) is using the cleaned-up and collapsed path as is (has been?) already done.
In case of any proxy/fcgi… setup strip any prefix and pass the remainder through. Said remainder comes from URL.RawPath.
