I’m trying to point two different domains to the same server/service:
Caddyfile part:
#Calibre comics server
comics.byrd.id.au {
reverse_proxy 192.168.20.2:8084
comics.byrd.au {
I recently shifted DNS to Cloudflare for the byrd.au domains. All my existing subdomains for byrd.au are working fine.
The original domain (comics.byrd.id.au) still works fine (and has been working fine for some time. This domain is not behind Cloudflare (yet).
Trying to access comics.byrd.au I get a “SSL Handshake failed - Error code 525” (via Cloudflare).
Caddy error:
Mar 28 16:46:06 aerie-server caddy[2231]: {"level":"error","ts":1711608366.212431,"logger":"http.acme_client","msg":"challenge failed","identifier":"comics.byrd.au","challenge_type":"tls-alpn-01","problem":{"ty>
Mar 28 16:46:06 aerie-server caddy[2231]: {"level":"error","ts":1711608366.2125094,"logger":"http.acme_client","msg":"validating authorization","identifier":"comics.byrd.au","problem":{"type":"urn:ietf:params:a>
Mar 28 16:46:07 aerie-server caddy[2231]: {"level":"info","ts":1711608367.7519946,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"comics.byrd.au","challenge_type":"http-01","ca":"htt>
Mar 28 16:46:39 aerie-server caddy[2231]: {"level":"error","ts":1711608399.3129358,"logger":"http.acme_client","msg":"challenge failed","identifier":"comics.byrd.au","challenge_type":"http-01","problem":{"type">
Mar 28 16:46:39 aerie-server caddy[2231]: {"level":"error","ts":1711608399.3130224,"logger":"http.acme_client","msg":"validating authorization","identifier":"comics.byrd.au","problem":{"type":"urn:ietf:params:a>
Mar 28 16:46:39 aerie-server caddy[2231]: {"level":"error","ts":1711608399.3130732,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"comics.byrd.au","issuer":"acme-v02.api.letsen>
Mar 28 16:46:39 aerie-server caddy[2231]: {"level":"info","ts":1711608399.3141387,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["comics.byrd.au"],"ca":"https://acme.zerossl.com/v2/DV90>
Mar 28 16:46:39 aerie-server caddy[2231]: {"level":"info","ts":1711608399.31418,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["comics.byrd.au"],"ca":"https://acme.zerossl.com/v2/D>
Mar 28 16:46:41 aerie-server caddy[2231]: {"level":"info","ts":1711608401.682929,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"comics.byrd.au","challenge_type":"http-01","ca":"http>
Mar 28 16:50:10 aerie-server systemd[1]: /etc/systemd/system/caddy.service:1: Assignment outside of section. Ignoring.
v2.7.6
Ubuntu MATE 22.04.04 LTS
x64
systemd
systemctl start caddy
(runs automatically)
caddy.service
# for your installation.
Type=notify
#root * /usr/share/caddy
#file_server
#Reverse proxys:
#Calibre book server
books.byrd.id.au {
reverse_proxy 192.168.20.2:8083
comics.byrd.id.au {
comics.byrd.au {
#Photoprism
photoprism.byrd.id.au {
reverse_proxy 192.168.20.2:2342
#Ghost blog
migratory.byrd.au {
reverse_proxy 192.168.20.2:2368
#Whoogle
whoogle.byrd.au {
reverse_proxy 192.168.20.2:5001
#Stirling PDF
pdf.byrd.au {
reverse_proxy 192.168.20.2:8070
#Memos notes
memos.byrd.au {
reverse_proxy 192.168.20.2:5230
