Hi, friends, loving caddy, although a bit newbie yet. First post here.
Newbie question
I have a question that maybe is basic for you, but worries me a lot:
I maintain a monolythic dashboard published at some URL like for example https://admin.example.com/
It has multiple features gruped by routing, like for example those:
* https://admin.example.com/feature-1
* https://admin.example.com/feature-2
* https://admin.example.com/feature-3
I run a caddy inside a docker container.
Currently the dashboard runs in another container behind the caddy, who maps all the internet traffic to https://admin.example.com into the internal container with something like this:
admin.example.com {
reverse_proxy * dashboard:80
where dashboard is the container name reachable from the caddy container.
The dashboard container serves the web from its internal root /.
Up to here, all works perfect.
Problem
The dashboard has been growing and we have approx 30 features. This reduces mantinainability of the code.
I want to split it into separated containers, something similar to a microservices approach but in the frontend. This will be a progressive splitting. Spring off feature-1 then next month feature-2 and so on.
Wondering
Say I start by stripping feature-2 out into another container:
dashboard-oldwill serve all the features including the obsolete ones from/ -
dashboard-newwill serve only the feature #2.
I’m wonder if caddy can help me to route:
https://admin.example.com/feature-2/*intohttp://dashboard-new/* -
https://admin.example.com/*intohttp://dashboard-old/*
Well in fact I already know that technically speaking it can. But there are 2 nuances I’m not sure how to handle: a) Path conversion and b) sessions.
My fear #1 - Path conversions
My fear #1 is about the “path conversion” back and forth from the outside and inside.
For example say the browser requests https://dashboard.example.com/feature-2/something-cool and it is routed to http://dashboard-new/something-cool
Until here, perfect.
But, what if this page contains links, AJAX requests, websockets, or whatever pointing to http://dashboard-new/tracking/id?
Reconverting this link from http://dashboard-new/tracking/nice to add again the stripped part feature-2 and rebuilding to https://dashboard.example.com/feature-2/tracking/nice seems something inside the HTML part and not the HTTP part.
As a context: I’m going to work with a dynamic frontend which is plenty of back-and-forth requests in the background (probably I’ll use React, not decided yet).
The intuition
I feel I should split the links into 2 groups: intra-feature and cross-feature.
If I work ALL intra-feature links with relative paths I guess I should be done: Have the page render always
tracking/idwithout the leading/I feel I should be okey here. -
And then use full hardcoded paths including the SSL schema for “jumping” to other features. If
feature-2has a global menu that allows to go tofeature-1andfeature-3that should be coded as the “externally accessible path” likehttps://admin.example.com/feature-1
I have silly wonderings as: Would it be easier if I configure the internal feature-2 container to respond the document-root into the same path than the extenal call?
Ie: I wonder if this is needed or not needed but is better or it’s is a silly dumb hypothesis:
https://admin.example.com/feature-2/*intohttp://dashboard-new/feature-2/*
instead of -
Fear #2 - Sessions
Appart from paths, there’s a huge problem with the sessions here… container dashboard-new needs to share session with dashboard-old.
I’ve no clue on if caddy plays a role here or not and where to start reading documentation about multi-container mono-session behind a caddy reverse proxy.
The help needed
Before going ahead, before spending days doing the feature segregation into another container, I want to ask you guys:
- if any of you has any experience in placing “separated features” of the “same application” into splitted containers behind a caddy routing different paths
- what are your good and bad experiences
- and what are the things I should consider yes-or-yes before going ahead
- session issues you have found
All your real-world experience in implementing all this is more than welcome!
