Here you are.
Nginx output for curl -v -L https://freehub.space
. Had to cut some data (encrypted and page source code) due to post length limit.
== Info: Trying 93.100.163.217...
== Info: TCP_NODELAY set
== Info: Expire in 200 ms for 4 (transfer 0x55c265100e20)
== Info: Connected to freehub.space (93.100.163.217) port 443 (#0)
== Info: ALPN, offering h2
== Info: ALPN, offering http/1.1
== Info: successfully set certificate verify locations:
== Info: CAfile: none
CApath: /etc/ssl/certs
=> Send SSL data, 5 bytes (0x5)
0000: .....
== Info: TLSv1.3 (OUT), TLS handshake, Client hello (1):
=> Send SSL data, 512 bytes (0x200)
<= Recv SSL data, 5 bytes (0x5)
0000: ....j
== Info: TLSv1.3 (IN), TLS handshake, Server hello (2):
<= Recv SSL data, 106 bytes (0x6a)
0000: ...f.....o.]....;R...%g.{....[.....&.. .k_...........F..n.....".
0040: ...t&!..............................h2....
0000: .....
== Info: TLSv1.2 (IN), TLS handshake, Certificate (11):
<= Recv SSL data, 4018 bytes (0xfb2)
0000: ....,
== Info: TLSv1.2 (IN), TLS handshake, Server key exchange (12):
<= Recv SSL data, 300 bytes (0x12c)
0000: .....
== Info: TLSv1.2 (IN), TLS handshake, Server finished (14):
<= Recv SSL data, 4 bytes (0x4)
0000: ....
0000: ....%
== Info: TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
=> Send SSL data, 37 bytes (0x25)
0000: ...! .VQ.*.q4...z+...B;.....K.....ys
0000: .....
== Info: TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
=> Send SSL data, 1 bytes (0x1)
0000: .
0000: ....
== Info: TLSv1.2 (OUT), TLS handshake, Finished (20):
=> Send SSL data, 16 bytes (0x10)
0000: ....d..WS..(....
0000: .....
0000: ....
== Info: TLSv1.2 (IN), TLS handshake, Finished (20):
<= Recv SSL data, 16 bytes (0x10)
0000: ........#(....sR
== Info: SSL connection using TLSv1.2 / ECDHE-RSA-CHACHA20-POLY1305
== Info: ALPN, server accepted to use h2
== Info: Server certificate:
== Info: subject: CN=freehub.space
== Info: start date: Oct 28 20:28:05 2021 GMT
== Info: expire date: Jan 26 20:28:04 2022 GMT
== Info: subjectAltName: host "freehub.space" matched cert's "freehub.space"
== Info: issuer: C=US; O=Let's Encrypt; CN=R3
== Info: SSL certificate verify ok.
== Info: Using HTTP2, server supports multi-use
== Info: Connection state changed (HTTP/2 confirmed)
== Info: Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
0000: ....(
0000: ....+
0000: .....
== Info: Using Stream ID: 1 (easy handle 0x55c265100e20)
0000: ....6
=> Send header, 75 bytes (0x4b)
0000: GET / HTTP/2
000e: Host: freehub.space
0023: User-Agent: curl/7.64.0
003c: Accept: */*
0049:
0000: ....8
== Info: Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
0000: .....
0000: .....
0000: .....
<= Recv header, 13 bytes (0xd)
0000: HTTP/2 302
<= Recv header, 15 bytes (0xf)
0000: server: nginx
<= Recv header, 37 bytes (0x25)
0000: date: Sat, 04 Dec 2021 20:14:19 GMT
<= Recv header, 40 bytes (0x28)
0000: content-type: text/html; charset=UTF-8
<= Recv header, 52 bytes (0x34)
0000: location: https://freehub.space/page/alado/main_ru
<= Recv header, 76 bytes (0x4c)
0000: set-cookie: PHPSESSID=0ift9m204bj9lg0mf4s10akpt7; path=/; secure
0040: ; HttpOnly
0000: expires: Thu, 19 Nov 1981 08:52:00 GMT
0000: cache-control: no-store, no-cache, must-revalidate
<= Recv header, 18 bytes (0x12)
0000: pragma: no-cache
<= Recv header, 2 bytes (0x2)
0000:
<= Recv data, 0 bytes (0x0)
== Info: Connection #0 to host freehub.space left intact
== Info: Issue another request to this URL: 'https://freehub.space/page/alado/main_ru'
== Info: Found bundle for host freehub.space: 0x55c2650ffe50 [can multiplex]
== Info: Re-using existing connection! (#0) with host freehub.space
== Info: Using Stream ID: 3 (easy handle 0x55c265100e20)
0000: .....
=> Send header, 93 bytes (0x5d)
0000: GET /page/alado/main_ru HTTP/2
0020: Host: freehub.space
0035: User-Agent: curl/7.64.0
004e: Accept: */*
005b:
0000: .....
0000: HTTP/2 200
0000: server: nginx
0000: date: Sat, 04 Dec 2021 20:14:20 GMT
0000: content-type: text/html; charset=utf-8
0000: set-cookie: PHPSESSID=erdigtupek9qjd3obgm95ql0np; path=/; secure
0040: ; HttpOnly
<= Recv header, 45 bytes (0x2d)
0000: strict-transport-security: max-age=31536000
<= Recv header, 127 bytes (0x7f)
0000: content-security-policy: script-src 'self' 'unsafe-inline' 'unsa
0040: fe-eval'; style-src 'self' 'unsafe-inline'; frame-src 'self';
0000: permissions-policy: interest-cohort=()
0000:
<= Recv data, 7744 bytes (0x1e40)
0000: ... .
<= Recv data, 8184 bytes (0x1ff8)
0000: pt src="https://freehub.space/view/js/autocomplete.js?v=6.4.1" >
0040: </script>
004b: <script src="https://freehub.space/library/jquery.timeago.js?v=6
008b: .4.1" ></script>
009d: <script src="https://freehub.space/library/readmore.js/readmore.
00dd: js?v=6.4.1" ></script>
00f5: <script src="https://freehub.space/library/jgrowl/jquery.jgrowl.
0135: min.js?v=6.4.1" ></script>
0151: <script src="https://freehub.space/library/sjcl/sjcl.js?v=6.4.1"
0191: ></script>
019e: <script src="https://freehub.space/view/js/acl.js?v=6.4.1" ></sc
01de: ript>
01e5: <script src="https://freehub.space/view/js/webtoolkit.base64.js?
0225: v=6.4.1" ></script>
023a: <script src="https://freehub.space/view/js/crypto.js?v=6.4.1" ><
027a: /script>
0284: <script src="https://freehub.space/library/jRange/jquery.range.j
02c4: s?v=6.4.1" ></script>
02db: <script src="https://freehub.space/library/colorbox/jquery.color
031b: box-min.js?v=6.4.1" ></script>
033b: <script src="https://freehub.space/library/jquery.AreYouSure/jqu
037b: ery.are-you-sure.js?v=6.4.1" ></script>
03a4: <script src="https://freehub.space/library/tableofcontents/jquer
03e4: y.toc.js?v=6.4.1" ></script>
0402: <script src="https://freehub.space/library/Sortable/Sortable.min
0442: .js?v=6.4.1" ></script>
045b: <script src="https://freehub.space/vendor/desandro/imagesloaded/
049b: imagesloaded.pkgd.min.js?v=6.4.1" ></script>
04c9: <script src="https://freehub.space/vendor/twbs/bootstrap/dist/js
0509: /bootstrap.bundle.min.js?v=6.4.1" ></script>
0537: <script src="https://freehub.space/library/bootbox/bootbox.min.j
0577: s?v=6.4.1" ></script>
058e: <script src="https://freehub.space/library/bootstrap-tagsinput/b
05ce: ootstrap-tagsinput.js?v=6.4.1" ></script>
05f9: <script src="https://freehub.space/library/datetimepicker/jquery
0639: .datetimepicker.js?v=6.4.1" ></script>
0661: <script src="https://freehub.space/library/bootstrap-colorpicker
06a1: /dist/js/bootstrap-colorpicker.js?v=6.4.1" ></script>
06d8: <script src="https://freehub.space/view/theme/redbasic/js/redbas
0718: ic.js?v=6.4.1" ></script>
0733: <script src="https://freehub.space/addon/gallery/lib/photoswipe/
0773: dist/photoswipe.js?v=6.4.1" ></script>
079b: <script src="https://freehub.space/addon/gallery/lib/photoswipe/
07db: dist/photoswipe-ui-default.js?v=6.4.1" ></script>
080e: <script src="https://freehub.space/addon/gallery/view/js/gallery
084e: .js?v=6.4.1" ></script>
0867: .<link rel="manifest" href="/manifest.json" />
0897: <link rel="shortcut icon" href="https://freehub.space/photo/prof
08d7: ile/m/2" />
08e4: ..<script>..var updateInterval = 80000;..var sse_enabled = 1;..v
0924: ar localUser = false;..var zid = null;..var justifiedGalleryActi
0964: ve = false;...var channelId = 2;.var preloadImages = 0;..var aut
09a4: o_save_draft = true;..var module = 'page';</script>....<meta nam
09e4: e="keywords" content="manjaro,kde,linux,python,cats,portugal,rus
0a24: sia,..........,....................,............" />
0a5a: <script>$(document).ready(function() { $("#nav-search-text").sea
0a9a: rch_autocomplete('https://freehub.space/acl');});</script><scrip
0ada: t src="https://freehub.space/view/js/main.js?v=6.4.1" ></script>
0b1c: </head>.<body >...<header></header>..<nav class="navbar fixed-t
0b5c: op navbar-expand-lg navbar-dark bg-dark">..<div class="container
0b9c: -fluid flex-nowrap">.....<div class="d-lg-none pt-1 pb-1">......
0bdc: .<a class="btn btn-primary btn-sm text-white" href="#" title="..
0c1c: ........" id="login_nav_btn_collapse" data-bs-toggle="modal" dat
0c5c: a-bs-target="#nav-login">...................</a>..........<a cla
0c9c: ss="btn btn-warning btn-sm text-dark" href="register" title="...
0cdc: ........... .............." id="register_nav_btn" >.............
0d1c: ..................</a>......</div>........<div class="navbar-tog
0d5c: gler-right">.......<button id="expand-aside" type="button" class
0d9c: ="d-lg-none navbar-toggler border-0">.....<i class="fa fa-arrow-
0ddc: circle-right" id="expand-aside-icon"></i>....</button>.......<bu
0e1c: tton id="notifications-btn-1" type="button" class="navbar-toggle
0e5c: r border-0 notifications-btn">.....<i id="notifications-btn-icon
0e9c: -1" class="fa fa-exclamation-circle notifications-btn-icon"></i>
0edc: ....</button>.......<button id="menu-btn" class="navbar-toggler
0f1c: border-0" type="button" data-bs-toggle="offcanvas" data-bs-targe
0f5c: t="#app-bin">.....<i class="fa fa-bars"></i>....</button>...</di
0f9c: v>...<div class="collapse navbar-collapse justify-content-betwee
0fdc: n" id="navbar-collapse-1">....<ul class="navbar-nav">.........<l
101c: i class="nav-item d-lg-flex">...........<a class="nav-link" href
105c: ="#" title=".........." id="login_nav_btn" data-bs-toggle="modal
109c: " data-bs-target="#nav-login">......................</a>........
10dc: ..</li>.............<li class="nav-item d-lg-flex">......<a cla
111c: ss="nav-link" href="register" title=".............. ............
115c: .." id="register_nav_btn">......................</a>.....</li>..
119c: ..........</ul>.....<div id="banner" class="navbar-text"><a href
11dc: ="https://freehub.space"><img src="https://freehub.space/images/
121c: fh_logo_3.svg"></a></div>.....<ul id="nav-right" class="navbar-n
125c: av">.....<li class="nav-item collapse clearfix" id="nav-search">
129c: ......<form class="form-inline" method="get" action="search" rol
12dc: e="search">.......<input class="form-control form-control-sm mt-
131c: 1 me-2" id="nav-search-text" type="text" value="" placeholder="@
135c: ......, #......, ?................, ...................." name="
139c: search" title="............ .... .......... @......, !..........
13dc: , #......, ?................, ...................." onclick="thi
141c: s.submit();" onblur="closeMenu('nav-search'); openMenu('nav-sear
145c: ch-btn');"/>......</form>......<div id="nav-search-spinner" clas
149c: s="spinner-wrapper">.......<div class="spinner s"></div>......</
14dc: div>.....</li>.....<li class="nav-item" id="nav-search-btn">....
151c: ..<a class="nav-link" href="#nav-search" title="............ ...
155c: . .......... @......, !.........., #......, ?................, .
159c: ..................." onclick="openMenu('nav-search'); closeMenu(
15dc: 'nav-search-btn'); $('#nav-search-text').focus(); return false;"
161c: ><i class="fa fa-fw fa-search"></i></a>.....</li>.............<l
165c: i id="notifications-btn" class="nav-item d-xl-none">......<a cla
169c: ss="nav-link text-white notifications-btn" href="#"><i id="notif
16dc: ications-btn-icon" class="fa fa-exclamation-circle notification
171c: s-btn-icon"></i></a>.....</li>.............<li class="nav-item d
175c: ropdown" id="app-menu">......<a class="nav-link" href="#" data-b
179c: s-toggle="offcanvas" data-bs-target="#app-bin" aria-controls="ap
17dc: p-bin"><i class="fa fa-fw fa-bars"></i></a>.....</li>....</ul>..
181c: .</div>....</div>.</nav>.<div class="offcanvas offcanvas-end" ta
185c: bindex="-1" id="app-bin" aria-labelledby="app-bin-label">..<div
189c: class="offcanvas-header">...<div class="lh-1" id="app-bin-label"
18dc: >.......<img src="https://freehub.space/photo/profile/m/2" class
191c: ="menu-img-2">....<div class="float-start pe-2">.....<div class=
195c: "fw-bold">Alado</div>.....<div class="text-muted">alado@fre
199c: ehub.space</div>....</div>......</div>...<i id="app-bin-trash" c
19dc: lass="fa fa-2x fa-fw fa-trash-o d-none"></i>...<button type="but
1a1c: ton" class="btn-close text-reset" data-bs-dismiss="offcanvas" ar
1a5c: ia-label="Close"></button>..</div>..<div class="offcanvas-body p
1a9c: t-0">.....<div class="dropdown-header text-uppercase">..........
1adc: .............. ...............</div>.....<a class="dropdown-item
1b1c: " href="https://freehub.space/channel/alado" title="............
1b5c: .. .. ...................."><i class="fa fa-fw fa-home generic-i
1b9c: cons-nav"></i>..........</a>.<a class="dropdown-item" href="http
1bdc: s://freehub.space/profile/alado" title=".................... ..
1c1c: .............."><i class="fa fa-fw fa-user generic-icons-nav"></
1c5c: i>.. ........</a>.<a class="dropdown-item" href="https://freehub
1c9c: .space/photos/alado" title="......................"><i class="fa
1cdc: fa-fw fa-photo generic-icons-nav"></i>....................</a>.
1d1c: <a class="dropdown-item" href="https://freehub.space/cloud/alado
1d5c: " title=".......... .. .................."><i class="fa fa-fw fa
1d9c: -folder-open generic-icons-nav"></i>..........</a>.<a class="dro
1ddc: pdown-item" href="https://freehub.space/cal/alado" title="......
1e1c: ............"><i class="fa fa-fw fa-calendar generic-icons-nav">
1e5c: </i>..................</a>.<a class="dropdown-item" href="https:
1e9c: //freehub.space/articles/alado" title="................ ........
1edc: ...."><i class="fa fa-fw fa-file-text-o generic-icons-nav"></i>.
1f1c: ...........</a>.<a class="dropdown-item" href="https://freehub.s
1f5c: pace/wiki/alado" title="Wiki"><i class="fa fa-fw fa-pencil-squar
1f9c: e-o generic-icons-nav"></i>Wikis</a>.<a class="dropdown-item" hr
1fdc: ef="https://freehub.space/ga
0000: ... .
0000: .....
<= Recv data, 4088 bytes (0xff8)
0000: .......... ............ - ................. ........ ...... - ..
0040: ........ .............. .................... ......... .... ....
0080: ........ ................ .. ...... .................. .. ......
00c0: ........ <a href="https://freehub.space/page/alado/about_ru">..
0100: Fediverse, Hubzilla .. .... ........ ........</a>. .... ........
0140: ........................ .................. ........-..........
0180: .... .. .............. ................ ......-...............</
01c0: p>.<h3><b>Q: </b>.............. .......... .....................
0200: ..... ........?</h3>.<p><b>A: </b>...... ............ ........ .
0240: ................. ................... .................... - ...
0280: ................. ........................ ...................</
02c0: p> .<h3><b>Q: </b>...... .......... .... .......................
0300: ... .... ........................ ........?</h3>.<p><b>A: </b>..
0340: .. .... ....................... ...... ........................
0380: .. .... ...... ...................... ......... .. .............
03c0: ., ............ ................ ...... .... ...............</p>
0400: .<h3><b>Q: </b>........ .... .. ........................ ......
0440: ...... .................. ................ ...... ............ .
0480: .............?</h3>.<p>A: ............, .... .. ................
04c0: .... .........................., ...................... .. <a hr
0500: ef="https://freehub.space/page/alado/hub_rules_ru">.............
0540: ... (..... 2 .. 4b)</a>. </p></div>...</div>..</div>.</div>.<!--
0580: Root element of PhotoSwipe. Must have class pswp. -->.<div clas
05c0: s="pswp" tabindex="-1" role="dialog" aria-hidden="true">...<!--
0600: Background of PhotoSwipe. ... It's a separate element as animati
0640: ng opacity is faster than rgba(). -->. <div class="pswp__bg">
0680: </div>...<!-- Slides wrapper with overflow:hidden. -->. <div
06c0: class="pswp__scroll-wrap">....<!-- Container that holds slides.
0700: ....PhotoSwipe keeps only 3 of them in the DOM to save memory...
0740: ..Don't modify these 3 pswp__item elements, data is added later
0780: on. -->...<div class="pswp__container">....<div class="pswp__ite
07c0: m"></div>....<div class="pswp__item"></div>....<div class="pswp_
0800: _item"></div>...</div>....<!-- Default (PhotoSwipeUI_Default) in
0840: terface on top of sliding area. Can be changed. -->...<div class
0880: ="pswp__ui pswp__ui--hidden">.....<div class="pswp__top-bar">...
08c0: ...<!-- Controls are self-explanatory. Order can be changed. --
0900: >..........<div class="pswp__counter"></div>......<button class=
0940: "pswp__button pswp__button--close" title="Close (Esc)"></button>
0980: ......<button class="pswp__button pswp__button--share" title="Sh
09c0: are"></button>......<button class="pswp__button pswp__button--fs
0a00: " title="Toggle fullscreen"></button>......<button class="pswp__
0a40: button pswp__button--zoom" title="Zoom in/out"></button>......<!
0a80: -- Preloader demo http://codepen.io/dimsemenov/pen/yyBWoR -->...
0ac0: ..<!-- element will get class pswp__preloader--active when prelo
0b00: ader is running -->.....<div class="pswp__preloader">......<div
0b40: class="pswp__preloader__icn">...... <div class="pswp__preloader
0b80: __cut">...... <div class="pswp__preloader__donut"></div>.....
0bc0: . </div>......</div>.....</div>....</div>... <div class=
0c00: "pswp__share-modal pswp__share-modal--hidden pswp__single-tap">.
0c40: ....<div class="pswp__share-tooltip"></div> .. </div>....
0c80: .<button class="pswp__button pswp__button--arrow--left" title="P
0cc0: revious (arrow left)">....</button>........<button class="pswp__
0d00: button pswp__button--arrow--right" title="Next (arrow right)">..
0d40: ..</button>.....<div class="pswp__caption">.....<div class="pswp
0d80: __caption__center"></div>....</div>... </div>...</div>..</div
0dc0: >..<script>.$(document).ready(function(){...// hide #back-top fi
0e00: rst..$("#back-top").hide();....// fade in #back-top..$(function
0e40: () {...$(window).scroll(function () {....if ($(this).scrollTop()
0e80: > 100) {.....$('#back-top').fadeIn();....} else {.....$('#back-
0ec0: top').fadeOut();....}...});....// scroll body to 0px on click...
0f00: $('#back-top a').click(function () {....$('body,html').animate({
0f40: .....scrollTop: 0....}, 150);....return false;...});..});..});.<
0f80: /script><p id="back-top"><a href="#top"><span></span></a></p><di
0fc0: v id="nav-login" class="modal" tabindex="-1" role="dialo
0000: .....
<= Recv data, 2515 bytes (0x9d3)
0000: g">..<div class="modal-dialog" role="document">...<div class="mo
0040: dal-content">....<div class="modal-header">.....<h4 class="modal
0080: -title">..........</h4>.....<button type="button" class="btn-clo
00c0: se" data-bs-dismiss="modal" aria-label="Close"></button>....</di
0100: v>....<div class="modal-body">.....<div class="mb-3">......<form
0140: action="https://freehub.space/page/alado/main_ru" id="main-logi
0180: n" method="post" >..<input type="hidden" name="auth-params" valu
01c0: e="login" />..<div id="login-main" class="d-grid gap-2">....<div
0200: id="id_username_wrapper" class="mb-3">...<label for="id_usernam
0240: e" id="label_username">...................... .......... ......
0280: ..................</label>...<input class="form-control" name="u
02c0: sername" id="id_username" type="text" value="">...<small id="hel
0300: p_username" class="form-text text-muted"></small>..</div>....<di
0340: v class="mb-3">...<label for="id_password">............</label>.
0380: ..<input class="form-control" type="password" name="password" id
03c0: ="id_password" value="">..<small id="help_password" class="form-
0400: text text-muted"></small>..</div>....<div id="remember_me_contai
0440: ner" class="clearfix onoffswitch checkbox mb-3">...<label for="i
0480: d_remember_me">.................. ........</label>...<div class=
04c0: "float-end"><input type="checkbox" name='remember_me' id='id_rem
0500: ember_me' value="1" /><label class="switchlabel" for='id_remem
0540: ber_me'> <span class="onoffswitch-inner" data-on='....' data-off
0580: ='......'></span><span class="onoffswitch-switch"></span></label
05c0: ></div>...<small class="form-text text-muted"></small>..</div>..
0600: .<button type="submit" name="submit" class="btn btn-primary">...
0640: .......</button>...<a href="https://freehub.space/register" titl
0680: e="................ .............. ...... .............. .. ....
06c0: .......... .. ......................" id="register-link" class="
0700: float-end">......................</a>..<a href="lostpass" title=
0740: "............ ............ ...... ..........?" id="lost-password
0780: -link" >................ ............</a><hr>...<a href="rmagic"
07c0: class="btn btn-outline-success">.................. ............
0800: ................</a>..</div>....<input type="hidden" name="0" va
0840: lue="" />..</form>......</div>....</div>...</div>..</div>.</div>
0880: ......<div id="page-footer"></div>......<div id="pause"></div>..
08c0: ...</section>.....<aside id="region_3" class="d-none d-xl-block"
0900: ><div class="aside_spacer_top_right"></div><div class="aside_spa
0940: cer_right"><div id="right_aside_wrapper" class="aside_wrapper"><
0980: /div></div></aside>....</div>...</div>..</main>..<footer></foote
09c0: r>.</body>.</html>.
0000: .....
and Caddy’s:
== Info: Expire in 200 ms for 4 (transfer 0x55865d4b0e20)
0000: .....
0000: ....z
<= Recv SSL data, 122 bytes (0x7a)
0000: ...v..~..d.P(&.[...j.Xo...j=...._prw.. e..).<.$.Nc7....-z......
0040: G...Q........+.....3.$... .{0..w....6..#..w:.S........k~.7
0000: .....
0000: ....
<= Recv SSL data, 1 bytes (0x1)
0000: .
== Info: TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
<= Recv SSL data, 15 bytes (0xf)
0000: .............h2
0000: .....
0000: .
== Info: TLSv1.3 (IN), TLS handshake, Certificate (11):
<= Recv SSL data, 3821 bytes (0xeed)
0000: ...._
0000: .
== Info: TLSv1.3 (IN), TLS handshake, CERT verify (15):
<= Recv SSL data, 78 bytes (0x4e)
0000: ...J...F0D. K'.)&Fw.....>I......>|h.~..,..... ..m..Y...I8v._4'.F
0040: v.JK.n."...+..
0000: ....5
0000: .
== Info: TLSv1.3 (IN), TLS handshake, Finished (20):
<= Recv SSL data, 36 bytes (0x24)
0000: ... ..\w..9k..b.,...q..<.0...HKE....
0000: .....
== Info: TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
0000: .
0000: ....5
0000: .
== Info: TLSv1.3 (OUT), TLS handshake, Finished (20):
=> Send SSL data, 36 bytes (0x24)
0000: ... .....B"./.....VF#./Sg..9...jGj..
== Info: SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
== Info: start date: Oct 29 21:01:34 2021 GMT
== Info: expire date: Jan 27 21:01:33 2022 GMT
0000: ....)
0000: .
0000: ....,
0000: .
0000: .....
0000: .
== Info: Using Stream ID: 1 (easy handle 0x55865d4b0e20)
0000: ....7
0000: .
0000: GET / HTTP/2
003c: Accept: */*
0049:
0000: .....
0000: .
== Info: TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
<= Recv SSL data, 130 bytes (0x82)
0000: ...~..:.......q......(;e...T..?....,..~T........u.......w..\,...
0040: .$....+..6.U..........)v.....c.{.2.7.........Ps-,6%..C....zB...u
0080: ..
0000: ....2
0000: .
== Info: Connection state changed (MAX_CONCURRENT_STREAMS == 250)!
0000: .....
0000: .
0000: .....
0000: .
0000: .....
0000: .
0000: .....
0000: .
0000: HTTP/2 302
<= Recv header, 57 bytes (0x39)
0000: alt-svc: h3=":443"; ma=2592000,h3-29=":443"; ma=2592000
0000: server: Caddy
0000: set-cookie: PHPSESSID=52n5r97okm2b4e5c7lppk9ip2a; path=/; secure
0040: ; HttpOnly
<= Recv header, 19 bytes (0x13)
0000: status: 302 Found
0000: content-length: 0
0000: date: Sat, 04 Dec 2021 20:15:43 GMT
0000:
== Info: Found bundle for host freehub.space: 0x55865d4afe50 [can multiplex]
== Info: Using Stream ID: 3 (easy handle 0x55865d4b0e20)
0000: ..../
0000: .
004e: Accept: */*
005b:
0000: .....
0000: .
0000: HTTP/2 404
0000: server: Caddy
0000:
