v2.4.5
I run Caddy v2 as a jail in truenas 12.
I run Caddy as a jail in truenas.
Jail version: 12.2-release-p6
service caddy start
#!/bin/sh
# PROVIDE: caddy
# REQUIRE: LOGIN DAEMON NETWORKING
# KEYWORD: shutdown
# To enable caddy, add 'caddy_enable="YES"' to /etc/rc.conf or
# /etc/rc.conf.local
# Optional settings:
# caddy_config (string): Full path to caddy config file
# (/usr/local/etc/caddy/Caddyfile)
# caddy_adapter (string): Config adapter type (caddyfile)
# caddy_directory (string): Root for caddy storage (ACME certs, etc.)
# (/var/db/caddy)
# caddy_extra_flags (string): Extra flags passed to caddy start
# caddy_logdir (string): Where caddy logs are stored
# (/var/log/caddy)
# caddy_logfile (string): Location of process log (${caddy_logdir}/caddy.log)
# This is for startup/shutdown/error messages.
# To create an access log, see:
# https://caddyserver.com/docs/caddyfile/directives/log
# caddy_user (user): User to run caddy (root)
# caddy_group (group): Group to run caddy (wheel)
# This script will honor XDG_CONFIG_HOME/XDG_DATA_HOME. Caddy will create a
# .../caddy subdir in each of those. By default, they are subdirs of /var/db/caddy.
# See https://caddyserver.com/docs/conventions#data-directory
. /etc/rc.subr
name=caddy
rcvar=caddy_enable
desc="Powerful, enterprise-ready, open source web server with automatic HTTPS written in Go"
load_rc_config $name
# Defaults
: ${caddy_enable:=NO}
: ${caddy_adapter:=caddyfile}
: ${caddy_config:=/usr/local/etc/caddy/Caddyfile}
: ${caddy_directory:=/var/db/caddy}
: ${caddy_extra_flags:=""}
: ${caddy_logdir:="/var/log/${name}"}
: ${caddy_logfile:="${caddy_logdir}/${name}.log"}
: ${caddy_user:="root"}
: ${caddy_group:="wheel"}
# Config and base directories
: ${XDG_CONFIG_HOME:="${caddy_directory}/config"}
: ${XDG_DATA_HOME:="${caddy_directory}/data"}
export XDG_CONFIG_HOME XDG_DATA_HOME
command="/usr/local/bin/${name}"
caddy_flags="--config ${caddy_config} --adapter ${caddy_adapter}"
pidfile="/var/run/${name}/${name}.pid"
required_files="${caddy_config} ${command}"
start_precmd="caddy_precmd"
start_cmd="caddy_start"
stop_cmd="caddy_stop"
# Extra Commands
extra_commands="configtest reload"
configtest_cmd="caddy_command validate ${caddy_flags}"
reload_cmd="caddy_command reload ${caddy_flags}"
caddy_command()
/usr/bin/su -m "${caddy_user}" -c "${command} $*"
caddy_precmd()
# Create required directories and set permissions
/usr/bin/install -d -m 755 -o "${caddy_user}" -g "${caddy_group}" ${caddy_directory}
/usr/bin/install -d -m 700 -o "${caddy_user}" -g "${caddy_group}" ${caddy_directory}/config
/usr/bin/install -d -m 700 -o "${caddy_user}" -g "${caddy_group}" ${caddy_directory}/data
/usr/bin/install -d -m 755 -o "${caddy_user}" -g "${caddy_group}" ${caddy_logdir}
/usr/bin/install -d -m 700 -o "${caddy_user}" -g "${caddy_group}" /var/run/caddy
caddy_start()
echo -n "Starting caddy... "
/usr/bin/su -m ${caddy_user} -c "${command} start ${caddy_flags} \
${caddy_extra_flags} --pidfile ${pidfile}" >> ${caddy_logfile} 2>&1
if [ $? -eq 0 ] && ps -ax -o pid | grep -q "$(cat ${pidfile})"; then
echo "done"
echo "Log: ${caddy_logfile}"
else
echo "Error: Caddy failed to start"
echo "Check the caddy log: ${caddy_logfile}"
fi
caddy_stop()
echo -n "Stopping caddy... "
if caddy_command stop; then
echo "done"
else
echo "Error: Unable to stop caddy"
fi
run_rc_command "$1"
mydomain.duckdns.org {
dns duckdns <APIKEY>
reverse_proxy http://10.10.10.189:8765
I can get Caddy v2 to work with Motioneye with a normal url. The solution found in topic #11845 works flawlessly.
But what I can’t get to work, is to change the base url. I would like to have my reverse proxy point to mydomain/cams for example.
caddy starts without errors.
I’ve tried the config below, but all I get is a white page.
dns duckdns
reverse_proxy /cams* http://10.10.10.189:8765
Before caddy, motioneye was running behind nginx. So I have a working nginx config:
http {
server {
listen 80;
server_name motioneye.home;
location /cams/ {
proxy_pass http://localhost:8765/;
proxy_read_timeout 120s;
