I’m trying to setup MonocleCam. I have caddy setup within in my network which is working well for my other stuff.
when trying to view my cameras using Alexa it cannot find my cameras.
Monocle was working well up to me introducing Caddy within my network.
Has someone managed to get this working? or could someone point me in the right direction to getting this resolved?
I have to admit I’m not sure how Caddy could get in the way.
Caddy talks HTTP(S) to your clients to serve web content. The app appears to use RTP and RTSP protocols to talk to your cameras. They shouldn’t be interacting at all, except if the app has a web page you’re proxying to.
So i’m having to use monocle-gateway which uses port 443.
when running the setup for monocle-gateway it looks to bind the application with this port
setcap ‘cap_net_bind_service=+ep’ /usr/local/bin/monocle-gateway
Now when I run caddy -host *mydomain
i get error
listen tcp :443: bind: address already in use
if I stop monocle-gateway it works just fine.
I appreciate this isn’t a Caddy issue, but any help getting this working would be appreciated.
Unfortunately you can’t have multiple programs listening on the same port. You’ll need to move monocle-gateway off port 443 so that Caddy can listen for HTTPS connections on that port.
Alternately, if Caddy isn’t at the edge of your network and you’re port forwarding from a router, you can move Caddy to a non-standard HTTPS port (8443 is a common alternative port) and have the router forward packets from 443 externally to 8443 on the Caddy host. It’s a bit more complicated than simply moving monocle-gateway, though.
arh ok, thank you for this information. I have tried to change Monocle to use another port but I just don’t think it possible.
would it be possible in noobs terms to tell me how to setup caddy to use a different port.
so from what you have suggested in the above comment. I will need to setup a port forwarder on my router from 443 to 8443 which is fine.
what would I need to do with caddy to get this working?
I think it just uses the run command you use to install the service with?
Just run the whole command and add -service install to it, and see if that works out. I believe it creates a systemd unit file if your init system is systemd, though, so you’re just as good to edit your existing unit file.
