1. Output of caddy version:
$ caddy version
Directly on Debian GNU/Linux 11 (bullseye) with Systemd.
automatically via systemd
Main Caddyfile
import {{ caddy_sites_conf_dir }}/*.caddyconf
First imported file
neururer.pjsmets.com
encode zstd gzip
root * /var/www/neururer.pjsmets.com/html
Second imported file
www.pjsmets.com, pjsmets.com
encode zstd gzip
root * /var/www/pjsmets.com/html
; Ansible managed
; source: https://github.com/mholt/caddy/blob/master/dist/init/linux-systemd/caddy.service
; version: 6be0386
; changes: Set variables via Ansible
After=network-online.target
StartLimitIntervalSec=86400
StartLimitBurst=5
Restart=on-failure
User=www-data
Group=www-data
ExecStart="/usr/local/bin/caddy" run --environ --config "/etc/caddy/Caddyfile"
ExecReload="/usr/local/bin/caddy" reload --config "/etc/caddy/Caddyfile"
; Use a minimal /dev
PrivateDevices=true
ProtectHome=false
; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
; This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy /var/log/caddy
; They further retrict privileges that can be gained by caddy.
NoNewPrivileges=true
I’m playing around with monitoring my Caddy setup and I’m wondering how to monitor the “golden signals”:
- Latency/response time
- Traffic
- Errors
For the response times, the Caddy docs already give some nice sample queries. For the other 2, it’s not so clear to me how to measure them.
- Traffic: the
caddy_http_requests_totalmetric gives counts per middleware handler. How can this be converted into total incoming traffic on the server? The docs warn about just summing everything up:Because all middleware handlers are instrumented, and many requests are handled by multiple handlers, make sure not to simply sum all the counters together.
- Errors: There is
caddy_http_request_errors_total, but this seems to combine 400 and 500 errors. Its it somehow possible to split this up?
See inline links.
