Thanks for that hint! I will add the missing struct documentation and JSON tags. (Judging by other plugins and the docs the json tags should suffice. We’ll see :-))
Any idea about the “homepage” link? It seems to use the import path, but the import path is not the github repo (due to the semver handling in Go).
Oh… yeah that was not my brightest moment. I’ll probably need to add another field for a link to the module’s code or maybe use logic like what https://pkg.go.dev does to automatically detect it. (Not sure how that works though.)
