I’m trying to build caddy with the cloudfare module so that I can do a tls challenge to generate certificates. I am getting an error saying that the module is not registered however when running list-modules the module is there. I have looked for errors in the caddyfile but can’t seem to figure out what is causing the issue.
Error: adapting config using caddyfile: parsing caddyfile tokens for 'tls': Caddyfile:48 - Error during parsing: getting module named 'dns.providers.cloudfare': module not registered: dns.providers.cloudfare
a. Docker Image:
Caddy installed through docker container with custom built image;
FROM caddy:builder AS builder
RUN xcaddy build \
FROM caddy:latest
b. Caddyfile:
Caddyfile is as below
{$DOMAIN1}:443 {
level INFO
output file {$LOG_FILE} {
roll_size 10MB
roll_keep 10
dns cloudfare {$CLOUDFARE}
reverse_proxy 10.0.0.50:802 {
header_up X-REAL-IP {remote_host}
{$DOMAIN2} {
level DEBUG
roll_size 10MB
roll_keep 10
reverse_proxy 10.0.0.50:8123 {
5. Extra information
Caddy list-modules shows that the module is listed as a non-standard module.
caddy list-modules
admin.api.load
admin.api.metrics
admin.api.pki
admin.api.reverse_proxy
caddy.adapters.caddyfile
caddy.config_loaders.http
caddy.listeners.http_redirect
caddy.listeners.tls
caddy.logging.encoders.console
caddy.logging.encoders.filter
caddy.logging.encoders.filter.cookie
caddy.logging.encoders.filter.delete
caddy.logging.encoders.filter.hash
caddy.logging.encoders.filter.ip_mask
caddy.logging.encoders.filter.query
caddy.logging.encoders.filter.regexp
caddy.logging.encoders.filter.rename
caddy.logging.encoders.filter.replace
caddy.logging.encoders.json
caddy.logging.writers.discard
caddy.logging.writers.file
caddy.logging.writers.net
caddy.logging.writers.stderr
caddy.logging.writers.stdout
caddy.storage.file_system
events
http
http.authentication.hashes.bcrypt
http.authentication.hashes.scrypt
http.authentication.providers.http_basic
http.encoders.gzip
http.encoders.zstd
http.handlers.acme_server
http.handlers.authentication
http.handlers.copy_response
http.handlers.copy_response_headers
http.handlers.encode
http.handlers.error
http.handlers.file_server
http.handlers.headers
http.handlers.map
http.handlers.metrics
http.handlers.push
http.handlers.request_body
http.handlers.reverse_proxy
http.handlers.rewrite
http.handlers.static_response
http.handlers.subroute
http.handlers.templates
http.handlers.tracing
http.handlers.vars
http.ip_sources.static
http.matchers.expression
http.matchers.file
http.matchers.header
http.matchers.header_regexp
http.matchers.host
http.matchers.method
http.matchers.not
http.matchers.path
http.matchers.path_regexp
http.matchers.protocol
http.matchers.query
http.matchers.remote_ip
http.matchers.vars
http.matchers.vars_regexp
http.precompressed.br
http.precompressed.gzip
http.precompressed.zstd
http.reverse_proxy.selection_policies.cookie
http.reverse_proxy.selection_policies.first
http.reverse_proxy.selection_policies.header
http.reverse_proxy.selection_policies.ip_hash
http.reverse_proxy.selection_policies.least_conn
http.reverse_proxy.selection_policies.random
http.reverse_proxy.selection_policies.random_choose
http.reverse_proxy.selection_policies.round_robin
http.reverse_proxy.selection_policies.uri_hash
http.reverse_proxy.transport.fastcgi
http.reverse_proxy.transport.http
http.reverse_proxy.upstreams.a
http.reverse_proxy.upstreams.multi
http.reverse_proxy.upstreams.srv
pki
tls
tls.certificates.automate
tls.certificates.load_files
tls.certificates.load_folders
tls.certificates.load_pem
tls.certificates.load_storage
tls.client_auth.leaf
tls.get_certificate.http
tls.get_certificate.tailscale
tls.handshake_match.remote_ip
tls.handshake_match.sni
tls.issuance.acme
tls.issuance.internal
tls.issuance.zerossl
tls.stek.distributed
tls.stek.standard
Standard modules: 100
dns.providers.cloudflare
Non-standard modules: 1
Unknown modules: 0
