Hi, newcomer here. Recently ive started testing caddy as potential replacement of nginx which ive been using for years. So far almost all things ive used in nginx do work in caddy as well, even mTLS (at least cert verification part which i was interested about the most)
The only problem i still have is how to filter remote ips in modular manner. In Nginx each IP range i use is under separate name (file which i import) which allows me to reuse it over all vhosts and change it in one place (file) if i need to.
/allow-home
allow 192.168.5.0/24;
/allow-secure
allow 192.168.20.0/24;
vhost part
include includes/allow-home;
include includes/allow-secure;
deny all;
I tried to replicate this in caddy.
import imports/allow-home
import imports/allow-secure
allow-home
@nonhome not remote_ip 192.168.5.0/24
respond @nonhome "Access Denied" 403
But offcorse this does not work because only the first rule is taken into consideration. Im looking for a way to either provide parameter for remote_ip dynamically (like remote_ip @allow-home @allow-secure etc.) or multiple matchers to respond part.
Ive also tried with vars but it seems i dont understand their concept yet
vars {home_ips} 192.168.5.0/24 # in caddy_vars file
vars {dmz_ips} 192.168.10.0/24
@denied not remote_ip {home_ips} {dmz_ips}
respond @denied "Access Deny" 403
I dont care if those are separate files or variables in some file as long as i can change single ip in one place (not multiple variables or files) for all hosts it occurs.
Well i tried many things, hard to provide one specific. Its more a concept problem, not functionality problem.
Docker compose
Ubuntu 22.04, Docker version 24.0.7, build afdd53b
docker compose up -d
version: "3.7"
image: caddy:latest
restart: "no"
cap_add:
- NET_ADMIN
- "443:443/udp"
- $PWD/imports:/etc/caddy/imports
- $PWD/logs:/logs
nginx:
restart: "no"
container_name: nginx
hostname: nginx
image: nginx:stable-alpine
Caddy proxies requests to nginx default page. Everyone can just copy and recreate this locally
ipmi.domanweb.lan:443 {
tls internal
output file /logs/ipmi.domanweb.lan.log
# SECOND attempt
reverse_proxy nginx:80
