v2
Amazon Linux2
I have next setup:
Caddy → Varnish → Nginx
As caddy cant brotli on-fly but Varnish can store brotli as separate hash i want to modify Accept-Encoding next way:
If Accept-Encoding ~ “br”, then header_up Accept-Encoding “br”
if Accept-Encoding ~ “gzip”, then header_up Accept-Encoding “gzip”
Else header_up Accept-Encoding “*”
And nginx will compress based on Accept-Encoding header, Varnish will cache separately and Caddy will response the way clear for the client.
Is there an option to “if” for header_up based on request header value?
Thanks.
