1. Caddy version (caddy version): v2.3.0
Installation steps:
yum install yum-plugin-copr
yum copr enable @caddy/caddy
yum install caddy
Running in background without systemd and using a Caddyfile
CentOS 7
caddy start
Not using right now (dev/poc server)
on_demand_tls {
ask http://localhost:3000/check
*.domain.com, domain.com {
reverse_proxy localhost:3000
:443 {
reverse_proxy localhost:3000 {
header_up X-Real-IP {http.reverse-proxy.upstream.address}
header_up X-Forwarded-Host {http.request.host}
on_demand
I’m trying to use the (awesome!) on_demand feature because our platform allows users to set their own custom domain (read the serving-tens-of-thousands-of-domains-over-https-with-caddy link post). We also let them use a subdomain too, so they can have user1.domain.com and custom-domain.com.
The custom domain is working properly, getting the certificate at the first request.
My real problem is that caddy didn’t issued a *.domain.com certificate. When someone access userX.domain.com it issues a CN userX.domain.com certificate instead of issuing/using the *.domain.com certificate.
Using the on_demand_tls ask solves the custom certificate for each subdomain (no more CN userX.domain.com certificate) but it didn’t trigger the wildcard certificate and the subdomain gets no issued certificate at all, returning a “This site can’t provide a secure connection”.
So what I’m trying is issuing a *.domain.com and domain.com certificate and for all the custom domains the on_demain certificate.
custom domain on demand are working fine
domain.comcertificate is working fine
sub-domains certificates are not working as expected
without the on_demand_tls ask = It’s issuing a custom certificate for each sub-domain instead of using/issuing the wildcard one - *.domain.com
with the on_demand_tls ask = It’s not issuing the wildcard certificate for *.domain.com
INFO using adjacent Caddyfile
INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
INFO http enabling automatic TLS certificate management {"domains": ["*.domain.com", "domain.com"]}
INFO autosaved config {"file": "/root/.config/caddy/autosave.json"}
INFO serving initial configuration
INFO tls.obtain acquiring lock {"identifier": "*.domain.com"}
INFO tls.obtain lock acquired {"identifier": "*.domain.com"}
INFO tls.issuance.acme waiting on internal rate limiter {"identifiers": ["*.domain.com"]}
INFO tls.issuance.acme done waiting on internal rate limiter {"identifiers": ["*.domain.com"]}
INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0002210a0"}
INFO tls cleaned up storage units
Successfully started Caddy (pid=12718) - Caddy is running in the background
ERROR tls.obtain will retry {"error": "[*.domain.com] Obtain: [*.domain.com] solving challenges: *.domain.com: no solvers available for remaining challenges (configured=[tls-alpn-01 http-01] offered=[dns-01] remaining=[dns-01]) (order=https://acme.zerossl.com/v2/DV90/order/XXXX) (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 3.098332016, "max_duration": 2592000}
I’m using Google Domains for the DNS and have those settings:
@ A SERVER_IP
* CNAME domain.com
www CNAME domain.com # not sure if needed since I'm using the * now
Without the :443 block the tls.obtain returns a error (added at 4) for the *.domain.com but it works for the domain.com certificate.
Added the ask directive so the subdomains (200 if it exists and 404 otherwise) arent getting issued as userX.domain but the *.domain.com certificates isnt issued too.
- Serving tens of thousands of domains over HTTPS with Caddy
- Https for dynamic subdomains and custom domains - #4 by matt
- Add option to force issuance of a wildcard cert · Issue #3200 · caddyserver/caddy · GitHub
- Is this the best/intended way to set up wildcard certs?
Thanks for the awesome project and support!
